Battery Failures
The battery failed in October, I found flat at 5v one morning with the boot lid open. The night before had been Halloween so not sure when or how the boot lid became open or was left open.  Either way the courtesy light should not have drained the battery after only 8 to 12 hours.  Got a jump start and took it to the local deler.  The battery was replaced free although it was just out of warranty.  That was nice.  But then it was the 4th battery on ths car.  The 3rd was shortly after I bought the car, the 2nd I found out about when discussing the failures, it was shown on the maintenance records.  The dealer cannot explain what is happening with the battery failures. The charging system is fine. There is no obvious drain on the battery.  The dealer did say that they had other Subaru batteries fail.  Is this a common issue with Subaru batteries?
You say "There is no obvious drain on the battery."
How did you come to that decision please?
Did you, for instance, measure the IOD?
IOD = Ignition Off Draw, which is notoriously difficult to measure.
"There is no obvious drain on the battery." - I am relying on what the garage told me.  I don't know if an IOD test was done.
Thanks for the replies.  The dealer said the car was charging OK.  An intermittent fault?  I'll have to keep an eye on it.
Thanks again.
Battery drain issues on late model Subarus is a very common issue (see various threads on this site and many others internationally).  A few key suggests for you:
1. Never leave the boot lid open for more than 10 mins. and if you do need to (say you're camping or loading lots of stuff etc.), then do the 'carabiner trick'.  Works with mine and easy to fix. or do this:
2. Always drive with the sidelights on and NEVER in auto light setting, unless you do decent mileages and avoid lots of short journeys.  The charging algorithm on modern Subarus is designed to flatter the mpg figures so doesn't engage the alternator to recharge the battery (thus less load on the engine so better mpg) unless it really needs to (which is never enough!).  Driving with side lights on (or AC, etc.) over rides the algorithm and forces constant alternator charging.
3. Go through all the car settings and switch off auto downloads and wifi connection, etc. as the car will keep searching for updates even when switched 'off' and parked on your drive etc....draining the battery.
4. Lots of OB owners, like me, tape the boot roof light 'off' so it can't be accidentally knocked on.
Hope you get it sorted.
Thanks very much for the sound advice which I will follow. Also bought a jump start battery pack – belt and braces.  A bit disappointing to hear it is common issue.  But I have some good news about the loss of my satnav maps which you can see in my other post.
I'm not sure if this is new information, and if it's useful for you or not, but you can access the dealership mode and also the factory mode on your Outback.  It's a little bit different to access on my Gen5, where I press and hold the home button while simultaneously pressing the tune button 6 times to get factory mode.  You are then able to access a range of menus.
I forget which one of the menus, but it's easy to find once you're in, that has a read out of the battery health in volts, when the car has either the engine running, or when not running but with the ignition on.  I find this is an easy way to quickly monitor the health of my battery, both on start up and/or just after the car has been stationary for a few hours to see if there's any drain.  It saves the hassle of getting a multimeter out, popping the bonnet and connecting the leads to the battery, etc.
Here's a relevant thread from the US OB forum which describes the access to the dealership mode in a Gen6 OB.
https://www.subaruoutback.org/threads/how-to-access-service-menu-gen6-outback.548488/
Ah.... looks like I've posted this info before:
https://uk.subaruownersclub.com/forums/topic/27361-secret-factorydealer-settings-access/
Thanks again.  I will have a look but I am a bit distracted and very pleased to find today that the self levelling and Steering Responsive Headlight (SRH) warning lights have disappeared.  See my post on this - briefly, they came on after the battery failure, the dealer couldn't reset them and quoted £800 to replace a headlamp control module.
Bought a 2.5yr old Outback Gen 5 and had to replace the battery within a month, the battery that was replaced did not look like the original factory battery.  I subsequently keep it charged monthly with a CTEK smart charger and meticulously watch voltage level, but just 6-months later, the battery is not holding a charge and looks like it needs to be replaced again. I always drive with side lights or manual full lights never auto. I have a cigarette lighter voltage meter to monitor the charging. Main dealer pretty unresponsive saying I need to take longer runs. Never had anything like this with the Legacy I'd owned for 8yrs before this. 9yr old battery and would start up fine after 2-3 weeks standing idle. I have to say, this is my third and last Subaru.
Many thanks Justin Time: It's the Wifi !!!
See image attachment.
My tools:
https://www.ctek.com/uk/battery-chargers-12v-24v/mxs-5-0-uk
https://carbatterygeek.co.uk/bm6-battery-monitor-review-12v-car/
I hope you can read the annotation, but it shows the battery dropping back to around 12.2V only 30hrs after a full charge (and presumably on its way to totally discharged). As soon as the WiFi is disabled it holds steady.
So, since I turned the Wifi off, it has not dropped another decimal volt for 10hrs. I'll get it back to full charge again with the CTEK and see if this continues.
I know this little BM6 device is not totally scientific but it's cheap and useful and saves the hassle of constant multimeter readings. The values it presents are two decimal places the same as the value on the cigarette lighter voltage monitor.
I've never had to  do this sort of stuff in 40yrs of owning cars. I don't think it's just Subaru.
BM6 battery voltage traceScreenshot_20250205-143504.thumb.png.e611b761da18196e1ce29ac3ed9ede78.png
My tools:
Ah well done.  Glad you got it sorted.
I've just returned from a 10 day trip away and the OB has been sitting on the drive all this time, so reading a few replies to this thread I was tentative about starting it up today! All well though, and I then took it for a 30 miles drive around the sunny north pennines, soaking up the bright, if icy cold, sunset.
