Stuck caliper?
I changed my front pads the other day did have a seized piston on one side! But the pads were really low!! Free'ed up the piston but seems fine on the new pads, just wondering if the pistons have more potential to seize the further out they are if that makes sense!
usually the further the piston goes out the more off set they can become, it wont be noticeable really to the eye but when you are putting the pistons in after a re-paint they can get stuck.
  • Replies 89
  • Views 16.6k
  • cusco scooby wagon
    cusco scooby wagon
    the wrx/pro are copy's by budweg i think and are sold by Brakes International  too,  there ok.     but feel a little cheap nothing replaces an original item,    and the photos of the old 4 pots is
  • Well with any luck this saga is over *crosses fingers* got the caliper off, then the disc was stuck so had to use a bolt to free it up, gave the hub a clean and put the new discs, pads and calipers on
  • I always dip the clutch anyway, always taught to do that by my parents incase car is in gear!!! And when parked in drive I leave handbrake off and in gear to stop locking brakes.
and yes am still alive just been playing with calipers and hunting pistons and thread-taps  etc.
am also trying to price up seal kits but not havin much luck, seems to be a dry patch at the moment.
Yeh makes sense bud. Never stripped scooby brakes but they must have big tolerances to allow piston to become offset! Don't take that the strong way fella. Tis not a slur on your knowledge. would have thought subaru would have made enough depth on the piston for that not to be an issue no matter how low pads are.
its all the crap that builds up round the piston seal its like plac and causes it to ware the chrome away and drags slightly to one side, usually its the bottom outside piston that starts sticking.
Maybe if they've got some card company that has more expensive fees than eBay so they try and encourage eBay purchases? Just a guess.
What's the deal Cusco with exchanging/refurbishing calipers? What's the turnaround? Price? I'm not in a hurry to do it yet but have some time off coming up, and my car can go for as long as needed on stands
your only in leeds mate, i could drop them off if need be, turnaround time is 2 weeks depending on my powdercoaters and other issues like different colored   calipers needed, usually ive a couple of calipers ready to send in so when i get an order i can build them up prior to your car being off the road usually if its local i can drop them off just as you have removed yours from the car.
just been looking on eBay at second hand calipers ,
 found these at £199.00 post-1114-0-91344100-1393367842_thumb.jp
 really.
THINKING I SHOULD UP MY PRICES NOW....
Excellent new thanks for the reply, I'm away to Kenya for a few weeks so will be getting bumped up my priorities list as soon as i get back & can afford it
Well with any luck this saga is over *crosses fingers* got the caliper off, then the disc was stuck so had to use a bolt to free it up, gave the hub a clean and put the new discs, pads and calipers on, forgot to take a photo with the wheel off but took some after a quick wash. And with a camera not a phone so quality is good :)
and this is what the passenger side caliper looks like, bit mucky and horrible and not the best photo as the light in my basement is a bit ****. But you get the general idea
I took it out of the drive to straighten it up and the pedal went to the floors, hadn't bled it completely apparently. Went a re-bled it and working as it should be now :)
the amount of times I have arrived at the end of the road and had to pump frantically is numerous - you would think I would learn but I always forget :rolleyes:
I learnt that lesson when I pulled out of my mates drive down a hill pedal to the floor oh ****, so went all the way to the roundabout at the bottom so I didn't have to burnout my handbrake lol
Guilty as charged :D
them calipers look OK on.
 my powder-coating place has just got mirror finish coatings but only in silver at the moment.
