pictures please!!!!
Looking to see the difference between lowering a forester with wrx impreza shocks & springs & lowering with wrx wagon shocks and springs....
I'm really stuck on which one to do.
Cheers
Cheers man thus is brilliant
Im pretty sure I don't have self levelling suspension.I will double check tomorrow.If so wrx will be going on lol
spring rate on that coilover kit is ridiculous for uk roads.
Do you mean on terms of how low it goes?
No spring rates, 10kg/mm front 6kg/mm rear, awful on the road, actually almost dangerous due to reduced grip & risk of being bounced of track on usual ruts etc on b-roads.
They wouldn't last 12 months before MOT failure but you probably crash before that.
Far better off going WRX if you lower it.
Also to check SLS status don't rely on canister or colour as later range of Tokico SLS are black & without canister, get the part number which is stamped on the strut & run it in Google or Subaru parts database.
