Posted
Thats just with the sidelights, they are awesomely bright and in daylight serve as DRLs.
  • Like 2
Posted
Used them for my reversing lights - they are a great replacement
Posted
Yes they would be great for reversing lights. But the ones on the outback are tiny LED s so wouldn't fit.
Posted
My GT-B has smoked reversing lights as standard and with normal bulbs they are useless, but I fitted a pair of CREE LEDs a while back and it made the world of differance. Highly recommended.
Posted
Ive had them on my cars for the past 5 years and been stopped for various things and not one rozzer has mentioned them. they`re not so bright as they blind anyone.....lets face it  the stock ones are **** poor.
Its supposed to be illegal to have blue lights showing on any car except emergency services.  :rolleyes:
Posted
lol @ rozzer
thanks mate.....just was on a bulb-selling site and the description on some (stupidly expensive) phillips T10's said they were ok for internal, but not external use.
Can't wait for mine to come now  :D
Posted
I'll have a look under the bonnet for you.
Posted
Shows the location of the bulb, if you take the Battery off it will be a breeze. Do this one first.
post-2579-0-34152300-1409838359_thumb.jp
Same on the other side, not as easy to remove the airbox but it will make the job easier if you do.
post-2579-0-29845800-1409838379_thumb.jp
At first it looks like the LEDs are too big to fit in the same hole as the stock bulb but if you line it up you`ll find they will just fit.
Posted
They are not quite as bright as the pictures make them seem, you obviously get glare in the camera lense.
So there`s no way anyone would think they are`nt stock bulbs.
Posted
Floor or wall? ......bit rainy over here so my day of cutting & buffing is off! it's that fine rain that soaks you through. :ph34r:
post-2579-0-47902000-1410012154_thumb.jp
Photo in daylight with sidelights on.
Posted
Had a look tonight as it was getting dark to see if I could locate the sidelight bulb holders....think I've found them and depending on how they come out, may not need to remove Battery or air box.
So - first question - are the holders a kind of figure 8 shape with 2 sets of wires coming out the back?
Second question - do I twist to remove holder from socket or just pull straight out?
Tried to locate video online unsuccessfully [emoji20]
Posted
Had a look tonight as it was getting dark to see if I could locate the sidelight bulb holders....think I've found them and depending on how they come out, may not need to remove battery or air box.
Yes, I think its the figure eight thingy. and yes, just a short twist and they come out. The LED is just a fit and just pushes back into its wee hole without needing to twist it.
If you can do it without removing said items then your a better man than I
Have fun :)
Posted
Although having said all that I managed to do it with things in place so your not so much better. :lol: But it does save the hands and fingers being scratched and cut up.
Going to be a fine weekend so enjoy! ;)
Posted
Led's in, literally a 5 minute job. Nice n easy once I knew where the bulb holders were. Thanks mate; such a cheap job, such a good result. Sides on at all times now I'm thinking [emoji106]
Posted
Wahey!...............Always nice when a plan comes together........you see what I meant by a tight fit?
Good thing about these, they last forever. :) and how bright are they huh?
Posted
Yeah mate, tight into the holder but fitted back through the aperture fairly easily. I'll try and get a pic when the light starts to go. They do look great though [emoji41]
I was going to ask actually; have you ever had to replace a bulb?
Posted
I swapped them over from the last OB, I was going to get a couple of spares, at the time they were only available from Australia but now they`re closer to home, no need. LEDs outlast normal bulbs and draw less power.
Register a new account
Sign in
