Lifting a Forester
looking at lifting my Forester, will need to change the rear as its sagging now & thinking of putting the Pedders kit on.
thinking of doubling up with this kit if anybody has used them/had any experiences?
http://www.subtle-solutions.com/product_info.php?cPath=21_24_26_45&products_id=97
I have been in contact, $300 delivered to the UK.
  • 4 weeks later...
customs released them & they arrived yesterday.
I have MOT on monday so see how that goes, then look into getting them fitted, I know i have a shock failing on the rear.
enquired about full geometry calibration today at Wheels in Motion (had previous cars done) & they said the Forester is fully adjustable on the camber so thats handy.
I will keep you posted.
had everything fitted today, bit of a balls up on my part…front is raised & looks fine, however I changed the SLS shocks on the rear but kept the standard springs & the !Removed! is dragging.
spoke to Pedders & the confirmed my suspicions, the standard springs to go with SLS shocks are a softer spring, so i have ordered the Pedders springs to match the non-SLS shocks.
So a couple more weeks & the rear will be a sensible height & will not look like i have a tonne in the boot.
mechanic that fitted it took about 1.5 hours to fit the spacers & replace the rear shocks & said its a nice kit.
oops, i just wanted to tell you if you change the struts you WILL have to change the springs also!
Pedders shoud know better when you ordered your new Pedder struts and should have told you that you will need new springs...
back in Australia i changed from SLS to standard struts by using Pedders springs and Ultima struts as one SLS strut was completly shot
if you going to dispose the SLS struts / springs can i get them?
Pedders did advise but its one of those moments of "i know best" & trying to save a few quid.
I have kept the shocks so far & 1 is knackered, I can push it all the way in by hand so its done well.
yeah, i was just asking as i actually want to have SLS back on my06 as when i bought her she already had non SLS struts done by the prevous owner.
i did kept the once when in Australia but when we moved back to the UK i dropped them in a skip  :o  as we had no space left for them in the shipping container :(
at last!!! my Forester is all done, first impressions of the Pedders spring & shock combo is that they are much firmer than OEM
The car is noticeably higher, I will post up some after pictures later, but heres the before images.
FRONT
REAR
here's the after pics, on a shoot tomorrow so will see how it gets on off road & it should help the new suspension settle down too.
Will see how it sits & how the tyres wear over the next few weeks & then look at getting a full geometry done, think i need to get some camber bolts for the rear.
FRONT
REAR
had everything fitted for a few weeks now & done a little off roading & finding the bumpy stuff, unfortunately no mud  :angry:
Ive not rubbed or scrubbed yet so all is good, normal road driving is fine, the Pedders kit on the rear is certainly stiffer & you can feel the difference on some road surfaces, but they absorb larger bumps very well.
Heres a few pics i took today.
think my next purchase is going to be some extra wheels for the winter months with some aggressive off road tyres
something like this. http://www.4x4tyres.co.uk/205-70-15/205-70-15-insa-turbo-special-track-mud-terrain-p-649.html  :wub:
