From TD04 to TD05 do I need to change anything? :P
Td04 on the left and Td05 on the right
  • Replies 65
  • Views 30.4k
    last year I did 4 dyno sessions in 2 different scoobs [emoji5] even if I've not had anything fitted I like it to go on rollers to make sure she's running rite at some point every year anyways .£ 500 f
  • I have no idea Yet lol
  • It will work i know people have done it and work fine more power then the td04. if you are remapping it bigger injector will be required to compensate for more air forced into the engine
There is quiet a difference in the fitting.When you turn the key over and blip the throttle and the car sounds angry
I think Front entry tdo5's were only fitted to newage as only the early phase 1 classics had the tdo5 top entry ,so that might be why the fitment is different .
I don't know much about newage tbh but I think the front entry tdo5 was fitted to the 2.5 ltr engines , so they're might have a bigger exhaust housing .
What's the diameter of the upipe end rick ?
Afaik when classics changed to front entry phase 1.5 (v3 onwards) they still used a front entry td04 for uk and wrx but opted for the vf series for the sti's, type r, rb5 ect .
Funny you should mention that Clive because mine came from a Bug eye lol
I didn't get the up pipe with it Clive.All I no is its huge.Ive got no cats at all with a 3inch to 2 1/2 all the way through and my rear can.The exhaust port going to the up pipe is massive.
It must have been a 2ltr if it was off a bug originally .
Last time I had mine on the rollers one of the operators said "fook me your scoob sounds brutal " [emoji5]
Gruppe slip jointed tubular headers
4 bolt upipe
Ported turbo hotside
3" cusco divorced wastgate decat down pipe
3" 5zigen slip jointed jasma cat back .
Nice burble under 3k [emoji41] but after then it sounds just plain DIRTY [emoji33] [emoji51] [emoji12]
Sounds nice.You can notice a big difference just when you blip the throttle
Went out in the beast before and the boost on the Td05 is well,you certainly notice it a big kick in your back lol.Im only on 0.8 bar of boost and that will do me till I have it mapped im playing safe and its still usable.God knows what its gonna be like at 1 bar lol.I also find it breaths better as well
When does it come on boost compared to the 04 rick ?
Not looked to be honest Adam but it doesn't hang about.
If it helps Adam my missus took the car on the motorway today and she wasn't flooring it and said it hoovers the motorway up lol
Haha just interested to see what differences there were.
Major difference Adam lol.There is no lag it just goes
Have you got a knock sensor fitted ? Bet it's going nuts
Yeah got a knock sensor in place from Factory and im only on 0.8 bar anyway.The injectors will fuel it anyway.When I did my td04 conversion there was plenty and was a little rich on boost but was safe.
Also need to find someone who maps on a sunday now
