Hi new to this and advice would be appreciated
Hi I've got a 1998 Impreza wagon turbo 2000, uk , I've got a engine number of 342779 , can anybody explain more from this or give me any advice to find out exactly what I'm working with? Thanks
Thanks in all honesty that's just mashed my head mate lol , I've looked through it and got myself no where
What's the number on your vin plate? And what information are you looking for exactly ?
Assuming it's standard.
I'm guessing it's an ej20 G or K engine, around 220 bhp with a td series trubo.
Hi mate I'm trying to find out what engine/block I've got in it to start with , and then yea all of the above lol , sorry if I seem abit thick ha
The vin number is jf1gf8kd3xg030858 with engine number 342779
No problem fella "scoob" is like a different language but once you understand the basics the rest is plain sailing .
Generally uk turbos are based on the wrx (same internals and cams) with a longer ratio box and different trim than their jdm wrx counterparts .
Of course it does depend on exact year and condition but a my98 uk will have a tdo4 turbo pushing about 0.7 bar producing 220 hp .
Typical "breathing" mods and a uprated fuel pump (just in case the original is a bit tired and fails) with a remap will max the turbo @ about 1.3 bar 270hp ish .
Next level of tune would be yellow 440cc injectors (if yours has greys 380cc) with a tdo5 or vf turbo you should see 320hp after a remap .
350 hp is about the max for internals and drivetrain (so it gets fairly expensive after then )
Your block type will probably be open deck
As for the engine version if the coil pack is in the centre it's a v3/v4 (phase 1.5 /inlet fuel set up)
If the coilpack is of set to the right as you look at the engine then it's a v5/v6 (phase 2 inlet/fuel set up)
Ask away if I haven't answered or confused a issue [emoji6]
Welcome to S.O.C
Okay Cheers mate , I'll have a check tomorrow as its locked away and will get back to you :) thanks again
