awd turbo engine help
hi, my awd turbo has 115k on the clock and isnt running just as smooth as it should and isnt quite as powerful as it should be too, its recently had a full oil change but what else can i do to get it back to running well? thanks
My classic is on 133k and just made 276hp on the dyno after a few mods. It depends what upgraded parts you have now. Could also be you getting used to the power. I thought mine felt slower but everyone else thinks it's a rocket.
Could change the fuel filter if its not been done for some time.
i changed the filters too, i dont think im getting used to it as i drive lots of other cars often as well, 1st gear is ok, 2nd is good, 3rd is great and 4th and 5th are very flat...
Have you checked for fault codes?
If it doesn't throw up any codes it's prob a faulty coil pack. My classic was running a bit lumpy and after replacing coil packs it ran much better.
