vaccum hoses
I think its a sensor, going to get some vac lines remove the T and put a straight through pipe! It was the rubber pipe from the intercool to dump valve :(
Cheers for your help mate, I owe you!
Do you have the restrictor pill fitted ? Don't forget to take it out of the vac lines before you bin the old lot off
I couldn't see one when i swapped the pipes over?
Should be a little brass pill a maybe 1cm long with a hole about a mm in the bottom hose if three port or near the turbo in the top hose on a two port
Ok iv managed to get a pipe to get it going and moving however im finding that when it gets to 18-19psi it stutters almost as if fuel cut is coming in. How ever its running a gems ecu, it has a hks fuel cut defender on i think its set to stock could this becausing it to cut?
Got the girlfriend up from london this weekend so think il struggle to get anything done ha. Have a look tonight!
