New owner of a uk 2000
post-5089-144309562619_thumb.jpg Hello everyone just bought this uk 2000 with 95,000 miles on the clock recent cambelt it has a full decat fitted and also yellow injectors my question is what is the best modification pass granted its not an sti and what engine would be in mine open deck I'm guessing and what would it be capable of it's a late 2000 model thankyou
Welcome to the club. I have the same model as you.
I have a 3" decat system, cosworth panel filter, 3 port boost solenoid, rcm fuel pump and remap. I get 276hp 280lb-ft. That is then limited by the TD04 turbo.
You can get those figures but anymore and you will need to replace the turbo.
I'd highly recommend the fuel pump to limit the chance of leaning out. As a guide a lot say the internals can take 350hp and that goes for the 5 speed gearbox too.
That's good to know and good figures too what are they standard ? it's my winter car atm I also own a Mazda 3 MPs and I use a Cobb ap to do logs and flash maps what's the thoughts on the same system used on a uk 2000 I've also noticed someone has removed the bov and blanked it off is this going to cause any damage ? Thanks
Standard UK models are 211-218hp. Different claims from different places.
If it's been blanked the pressure will travel back through the turbo causing it to stall. Sounds nice with a flutter but over time could cause damage. They have recirculation valves as standard.
Best get that sorted asap are you still running standard recirc or bov ?
I use the recirc. I have a good bit of whistle on boost anyway. Bov seem hit and miss. Gfb make a good adjustable bov @£190. If I did get one it'd be that. A forum member bought one recently and said it works really well.
I'll look into that I'll see if I can find a standard recirc for now then get a gfb once I know the car after running it abit never know what might happen it explains the lag I've been getting and bogging in high gears running no valve
Running the GFB at 100% atmo and have zero issues with it, get the occasional loud pop out of the exhaust... always puts a smile on my face :D
oh and welcome to the club :D
To be honest it needs mapping for those mods first of it hasn't been
Hi mate
Welcome to the club
Hello & welcome as far as I'm aware the cobb access port would only work on newage cars, if your wanting a map best off doing it properly on a rolling road as they are all vary different in the ability extract power out of your engine depending on wear etc last thing you'd want is to load a generic map or one that somone has had on a similar car only for it to go pop a few weeks down the line
Hi Will, welcome.
i have a UK 2000 Terzo running a safe 323bhp, if it helps i have listed all the mods i have on mine:
Td05 16g Turbo
Walbro 255 fuel pump
Piper X Cone filter
Fuel pressure regulator
Bellmouth downpipe
Decat 3" full stainless
Boost controller
ESL daughter board
Front mounted intercooler (Not really required until you get to 400bhp but helps with heat soak in town)
NGK Iridium IX spark plugs #7s
Magnecor KV85 ignition leads
Bailey atmospheric DV (chatters nicely, not too load)
Really want to get over the 350 mark but that comes with a 2k+ price tag if i build it... :wacko:  :blink:  :D
Anyway, hope that helps.
Thanks all that's all been real helpful sorry I didn't reply earlier this tapatalk app hasn't been giving me notifications, first things first after running the car for a few weeks now I love it I also own a Mazda 3 MPs were the uk2000 lacks in power it makes up in grip and pure fun I want to get good power out the car , just out of question what engine would I be looking for as an upgrade that I can build over time and put in the car as I know this is the open deck engine which a friend runs in his rally car running antilagg fully built at 370bhp with a tdo5 my options after the winter and the MPs is back is either build this engine or buy a already more powerful engine and build that thanks that's a fairly good list of mods what boost controller do you recommend? And we're do I find a piggy back Ecu it turns out the car has the bell mouth downpipe too happy days
Does an upgraded recirc still give the psst pssst or is that only Bov? Dumpvalve sound?
Thanks in advance.
Why not start with a map, gives you time to amass parts then less downtime between motor swaps?
A map should get you to around 270 ish before anything else,
As for ecu you'll either need an apexi fc & commander or esl board, which is newer and allows Al & launch plus twin maps ask savage what he thinks as he has had both in his at some point
Esl won't work on v5, you will need apexi / ecutek / Simtec / alkatec / eculabs
300 plus feels very quick in a classic, my mate has a 380bhp focus and doesn't come close and I'm st about 330
I Just saw classic and assumed [emoji1]
It's coming I'm told , the esl guy lives about 10 mins from me should go bang on his door
Any recommendations on we're to go for any of them routes ? It feels quick at 215 Bhopal so I get what your saying at 300 youl feel a big difference
What's your budget ?
I don't have one lol whatever is best really for the application I like the car so I'll spend abit on it I think I need some plugs first I have a slight miss on idle however it could be because of running no recirc valve I reckon what's the standard idle mine idles at 800rpm
That's good then same hear I'll give it a service tomoro see how it goes thanks that would be a great help
Service, hi flow panel filter & map would be my starting point
