arrgh
After two day monitoring cold level seems to be halfway between min and max on ex tank and hot is on the max line. This sound abiut right ?
that does sound about right ;)
as far as i know the coolant you have should be fine, just make sure you drain the system as there are 2 types of coolant and they can't be mixed,
here you go, pretty good write up here
