Posted
Hi Guys,
My 1997 Impreza turbo is having a little problem, so when the car is warm and I pull up to traffic light ect the revs go really low and today it cut out.  I've been reading a lot about cleaning the idle control valve but on the forums it's states to have a replacement gasket.  I can't find one anywhere? I found loads for the 2001 model but not the classic.  Can anyone help me out.
Posted
Think a couple of members have cleaned their icv (possibly using electrical contact cleaner) but hopefully someone else who has done it will point you in the right direction
Posted
I should have a breakdown guide in my manuals, I'll check tomorrow and get some pictures asap
Sent from my HTC One_M8 using Tapatalk
Posted
It's on my never ending list to do, if you take it all apart there's a diaphragm inside which would be better off being replaced instead of re used,
And What ever you do don't unscrew the two Philips heads on top of the sensor without marking them 1st at least, if that goes out of alignment you'll be Tring to reset the idle forever
Posted
Might be worth just checking the air pipe(s)? connecting to it. From what I remember they can go a bit brittle...
Posted
According to the manual this is how you clean it!d564cb8e100ca0e1af97c492d4caad6f.jpg
And here is the torque rating
Sorry bout the late reply
Register a new account
Sign in
