joel12900 Posted March 27, 2016 Posted March 27, 2016 My 2002 Bugeye failed its MOT the other week on 10 things -_- but ive got half of them sorted now. One thing i had to get done was welding on my front sub frame. I took the car back to the garage the other day to fix the rest of the stuff but they said they cant pass the MOT cause the sub frame was in a grey area as its still slightly rusting and they know its been welded :/ My question is, does anyone know if it will be easier or cheaper to get another front sub frame fitted or to get it welded more. Enough just to pass its MOT?? Thanks.
savage bulldogs Posted March 27, 2016 Posted March 27, 2016 I can understand where the mot tester is coming from, as if it's badly corroded in one place it's probably not as strong as needed elsewhere. A clean second hand subframe off a jdm of the same year would probably cost under 拢100 but I'm not sure how much it would cost to fit . If it's not broke .....upgrade it 馃槉
joel12900 Posted March 27, 2016 Author Posted March 27, 2016 The tester noticed i was part of SOC and said to ask on here. Cause I was thinking about maybe going back to the guy who welded it and seeing if he can do a little more, then take car to a different garage for its MOT and hopefully see if they pass it (Y) I literally cant really afford to buy another frame and fitting. I had a 拢850 repair in January, then i had to borrow money for my insurance for this year and welding to be done. And just bought a Cobra exhaust cause my exhaust now is blowing -_- Haha so its not really looking good.
quit Posted March 27, 2016 Posted March 27, 2016 Sorry mate sounds like you need to get rid , if you can't afford to keep or fix it properly will just end up dangerous
joel12900 Posted March 27, 2016 Author Posted March 27, 2016 I do need to get rid but i cant even afford that haha :( I had air ride put on the other month and thats on finance over 1 year ( Yes i know people dont like air on a Scooby but i like it ) Ive still got like 8 months left to pay -_- I am slowly trying to fix it up still.
Jay762 Posted March 27, 2016 Posted March 27, 2016 By the time you have paid for a bit more welding and the cost of an MOT at an alternate garage that will be close on 拢100. I would hold out / save for the subframe replacement. Example on evil bay at moment http://www.ebay.co.uk/itm/Subaru-impreza-WRX-STI-newage-bug-blob-howk-c-subframe/252332212172?_trksid=p2045573.c100034.m2102&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35951%26meid%3Dc91fb77fc9a348289fc24b785dd2860a%26pid%3D100034%26rk%3D4%26rkt%3D4%26sd%3D181995533674 A wire brush and some smoothrite before fitting should keep the rust away for a bit
joel12900 Posted March 27, 2016 Author Posted March 27, 2016 But does anyone have an idea on what it would cost to fit it?? :/
Jay762 Posted March 27, 2016 Posted March 27, 2016 I would do it myself as I have jacks, stands, sockets etc - sorry I wouldn't know what a garage would charge
joel12900 Posted March 27, 2016 Author Posted March 27, 2016 I have all those too. Its just when it comes to corroded bolts, bolts getting stuck and whatever else. Im no good at them :/ but no worries. Thanks anyways :)
Piggysniffer Posted March 27, 2016 Posted March 27, 2016 What about you take it off (if it's the one in the link) (and if the bolts are undo able) and then take it for an mot with it not on the car, then bolt it back on after and look for a cleaner one later on
joel12900 Posted March 28, 2016 Author Posted March 28, 2016 Yeah im not ganna do that haha, cause im pretty sure you need it on! As thats one of the things they look at when testing as its a structual part of the car (Y) Sent from my GT-I8190N using Tapatalk
Piggysniffer Posted March 28, 2016 Posted March 28, 2016 i think you will find its a case of , if it's not there it can't be tested, rather like the spare wheel, most mot stations wouldn't even realise or even know, you don't need it to drive the car and lots of people take them off completely, have a Google, consensus is that they are there for extra crash protection, and from what I can gather the spec C cars do not have them fitted at all due to weight reduction 2
Gaulson Posted March 29, 2016 Posted March 29, 2016 It's a quickish job to swap a subframe on the ramp, I replaced mine it's just 8 bolts. You are looking at an hour maybe two tops. Got mine from the breakers for just under 拢50 so just ring round. Just to note the STI subframe has 2 extra bolt holes so try to avoid. 2
Piggysniffer Posted March 29, 2016 Posted March 29, 2016 Think I picked mine up from g&r Harris breakers for 40 quid on my 03 blob, like you said, easy job, even moody looking bolts came out fine, did mine on jacks, just had a thought...... If you had the plastic engine undertray on the car they wouldn't be able to see most of the c frame to mot it ?
Gaulson Posted March 30, 2016 Posted March 30, 2016 Not sure if it covers all of it, the front might be covered but I know around the sides it's not.
Register a new accountSign in
