ARBs r they worth it
Thinking of changing ARBs front n rear on wrx hatch will I notice a big difference in handling car already lowered on h&r springs but still to much body roll n no confidence when turning in. Would it be better to just get sum Coils on cos I no standard dampers r ****
Do the rear bar 22mm is the best option should dial out the understeer on the front,
In my opinion it's one of the best £ for £ mods you can do
Is it worth doing front aswell while doing rear or is it not worth it for wat difference it will make
Nah j wouldn't bother with the front unless you do track work, 22-24mm is considered pretty stiff up front
Rear it is then been looking at whiteline 22mm adjustable one so probably go that route
Cheers I'll av a look into it gotta be worth the money cos it's no good at min drive my brothers focus st n it's a better car in corners
I drove my boss' new shape ST3 the other day... really nice car
Mi brothers is shape before wi 2.5 engine IMHO one of best engines ever put in a hot hatch
and it's a volvo engine! :D
I no crazy not as bulletproof as ppl think tho they suffer wi cracked liners when u start pushing power outta it so need block mod n standard clutch is at its limit at 225 bhp
Get front and rear arbs and drop links will transform the handeling
It's r8 tail happy at minute in wet so easy to get back end to step out
