Posted
Hi does anybody know what SBF 13 in the engine compartment fuse box controls.
Posted
Does it not say on the underside of the fuse box lid ?
Can you snap a pic as I'm having trouble thinking which one it is
Posted
On the underside it says SBF 13. It's a 50 amp fuse.
Posted
On my 94 impreza there's only a few 50 amp fuses .the only 2 I can think of at the moment are ....
The "fusible link" which is basically a 50 amp wire with a spade connection on either end .This is the fuse for the starter motor .
And the other is for the charging system .
Hopefully one of the leggy boys will know .
Posted
Is it not covered in the manual? With that size you are looking at something that draws a fair bit of current. If it was me I would pull it then try starting the car :smile:
  • 2 years later...
  • 3 months later...
Posted
In Subaru Diesel engines "sbf13" 50A fuse controls glowe plugs. Any short circut problem, mostly one of glowe plugs malfunction burn this fuse.
Solution: glowe plugs check and change
Register a new account
Sign in
