H6 idler pully or bearings?
Had a strange noise on startup for a while now. This afternoon it stopped abruptly and when I looked the pulley had dropped right off. :rolleyes:
Anyone know if it`s a replacement pulley or just the bearings?
Cheers
Steve
I'd presume it's a new pulley needed as more than likely sheared off ?
Looks like the bearing seized and the bolt just unwound itself
Sent from my SM-G925F using Tapatalk
I think if the idler bearing bolts are over tightened (not torqued down properly ) they can snap , so check to see if the bolt is in 1 piece . As you might need to extract the broken bit and buy a new bolt with the new idler bearing.
It`s being sorted today, both the idler and tensioner pullys come as a set and they are something which needs replacing occasionally
:eek:.
Yep. It was the tensioner pully though.....my mistake.
But I also will need the idler pulley pretty soon which I can't seem to find anywhere.
It was £130 fitted
Tell tale sign Dave is the noise on startup.
