3rd scooby but new member
wagon v5 owner here !
no difference in power between saloon or wagon, they share the same everything about from the rear seats and boot etc
it has a slightly wider track and different rear shocks to accomodate the extra load it could carry over the saloon.
I would get a full service done. You should be hitting 0.9 bar which should be about 220-221bhp model. Also open up the passenger footwell, some 10mm bolts and check what ecu you have. There are 4 options available on these. The sticker in the middle E3 etc is a start then the reference code should start with a A... The ones with a 800-01 at the end have a more aggressive map on that the others.
Power gains:
Ecu tek or Eculabs only options to keep the existing ecu - Eculabs is open source and better and has more toys, about 420-550 depending on what set up you have
Also in terms of power,
Your standard td04 turbo is capable of about 280bhp.... i think this makes a very fast classic when boosting to about 1.2-1.4 bar
Upgrades:
VF28 £200 very good turbo
VF35  £300 even better
VF34 £400 even better
