Classic Impreza headache problem
Hello fellow scooby owners right bare with me this is long winded and head hurting
Ok well ive rebuilt a subaru impreza 1995 wrx from ground up complete shell strip i never had a engine so i bought another subaru 1995 wrx that had been stood for years with a engine problem it wouldnt run unless map is unplugged so i thought not to worry ill be stripping engine anyways
So i removed engine replaced headgaskets,and different heads i relapped all valves etc
Different inlet manifold with
Throttle position sensor
Idle valve
Injectors
Loom
Maf
Coolant temp
02 sensor
Fuel filter
Adjustable fuel reg set to 3 bar
Ecu
Vac pipes
Map sensor
Boost sensor
Converted back to single coils
Now ive replaced all these 3 times with ones off my friends and still same
Ive measured voltages on throttle sensor and are within tolerences
I can get it to run for 2 seconds lumpy and dies if i disconect throttle sensor and maf it starts no problem and ticks over sweet just cant rev obviously if i reconect while running it dies
Connected black connectors no codes stored
Much appriciated reading this far
Im really hoping someone can give me a pointer something im missing
Thanks so much
When you say different inlet manifold, was it the same as the original (phase 1 ) ?
Or was it the later phase 1.5 with the single coilpack in the centre of the inlet manifold ?
Thanks for replying
Sorry i should of made it clearer i replaced it with another standard v2 one so both same
Coils are in the side
previous owner did newage conversion i thought that could be problem so converted back but still same
If i disconnect maf and throttle sensor it starts and idles spot on no misfires just wont rev up and loads of unburnt fuel im guessin because ecu in limp mode
I do ecu reset everytime i disconnect sensors
Has it definitely got a jdm ecu in it ?
Changing the tps or icv can cause issues if the manual adjustment is in a different position . As the ecu thinks it's in a different position .
Have you attached the engine loom earth to the inlet manifold?
Did you reinstall the ignition igniter behind the boost solinoid bracket. As this is by passed when doing a newage coil pack conversion?
Def ecu for my car i run a z4 ive swapped it with a 2c i think at min its what came with the spare car i bought
I thought same thing adjusting the tps ive used multimeter and is set to 4.8 closed and 0.9 open
The map sensor and igniter etc ive replaced the whole piece with what came with my shell so different to my spare car one
Thinking about the earth i think ive bolted to manifold and not the starter
It definitely sounds like a electrical issue to me , seeing as it idles ok with the maf and tps unplugged.
Does seem strange that your not getting any codes up though . When you reset the ecu (I think) the boost solinoid and relays "click" ect . Does it do that ? , Ie is the reset /eml light definitely working ?
Def electrical not mechanical which is half good since replaced heads etc
Yeh fans kick in and solenoids click
If i move tps or disconect maf the codes come up when count the flashes so i know check engine light does register
Ill check on that earth lead tomorrow
Do appriciate your time
Im guessing i need to find a wiring diagram there must be something linking the two to put it into default setting and make it run
No problem ,bud .
Unfortunately sparks ain't really my thing .
there's a link to free pdf files on 1 of the first few pages of my sticky build thread on here which will have the diagrams on .
The loom earth should bolt onto the inlet manifold with a earthing "eye" just behind the start of the fuel hard lines (above cylinder 4 )
Keep us posted and best of luck
Quick update i moved earth to starter and fitted new plugs gapped to 0.7 and bingo starts to a degree with everything connected and revs up just something not 100% like a misfire so going to swap coils tomorrow thanks for replying savage bulldogs only you out of a 109 people who viewed this post and on scoobynet replied
Id have replied if I coulda helped, but didn't have a scooby doo mate 😕
Plus I only just read the thread lol
Your welcome mate , you nearly always get a reply on here .
We like to help if possible
Do you know if your injectors are the right ones for the ecu (phase 1 grey 380's or yellow 440's ) did you use new "o" rings when you fitted them ?
Do you know if the fpr is reading true ?
as a slight change in pressure can make a big difference to the fueling .
Thought I'd add I once connected the coil packs on cylinder 1 &3 the wrong way round [emoji55] it ran lumpy on 2 cylinders and even drove up to 3k .
Haha piggy sniffer 'scooby doo' amused me
Fpr is brand new sytec one but i can test it to make sure does anyone know what pressure should be roughly
The injectors was already in the manifold 380 standard ones i am wondering which way the connectors go ones grey and ones white i think white goes to front engine
Same with coils i believe white connector is front coils the wire dosnt seem to stretch to get them wrong way round
cheers guys
Im with Piggy - read - was here in spiritual support but can offer nothing more than positive vibes for this one :whistling:
Positive vibes better than no vibes ☺
Iirc the tps should read 0.5-0.8v closed and 4.7-4.9v open. if it is the wrong way itll be trying to run open and closed loop the wrong way around.
switch the TPS positive and negative the oposite way around to get the sensor to read correctly
