Garage Recommendation Please
Hi hope this is in right place,I have 1998 2.0 impretza wrx sti,this needs valve clearances adjusting.Where in oxfordshire
can i get this done?
Yep the valves work with hydraulic lifters . Unless your lucky enough to have the "under bucket shim " type heads ,then they can be adjusted slightly by fitting different size shims .
Either way your probably looking at a engine out and top end rebuild unfortunately.
On 10/11/2016 at 0:00 PM, Tidgy said:
why do you need the valve clearances adjusted? thats a head rebuild job.
Yeah i know,had it serviced at edmotorsport.co.uk and he said they needed adjusting.
When i tried to book it in , he said had not got his shim kit.
Yes they are under bucket shim type.And i know what it entails,
just need somewhere to get it done.Thats my problem
