Rear brake dust covers
Hi I have been having some noise from my rear brakes like a constant grinding at low speed that comes and go's and the discs did not look great so ordered some new discs pads and handbrake shoes from eurocarparts and am having the garage down the road fit them.  They called me in as the car was on the ramp to show me what was making the noise as I thought it was the handbrake shoes turns out its the disc dust covers that have gone rotton leaving bits of rust in the bottom.
What are my options for replacing the dust covers or can they just be got rid of and cut off.  The garage are going to clean them up the best they can with a wire brush on a drill and put a bit of anti rust paint on for now.  I have MOT next month as well so am wondering if they will affect that, its a 05 plate blob eye WRX 2.0.
Cheers Graham
Www.importcarparts.co.uk should be able to sell you some nice new ones. Could remove them before mot not sure if it's a fail for not having them though ?
You won't fail mot if you take them off as they not an mot-able item buddy :thumbsup:
Hi thanks for the replys, I had a look on that import car parts site but they are expensive.
I will probably get rid of them unless I can find replacements a bit cheaper.
Cheers
breakers rarely have them as they rot, i went to get my grinder to cut them off to do the 2 pot upgrade and just basically pulled them they popped off
Well it looks like they are about 75 quid each and it's the whole assembly that the drum attaches to and can only be changed if you remove the hubs.
just cut em off dont need them
