FMIC Fitting Newage Impreza
Jay762
Right today i fitted my front mount
I took some pics as i went on as nobody had any pics for refrence to show me so i thought if i can help somebody out it only takes afew seconds step by step so here they are
Start
Bumper and grill removed
Crash bar thing removed
New intercooler mount in its place
This is smaller than the old bar so i filled the large holes with polostyrine removed off the bumper
These 3 tabs need to be cut off (paint all exposed metal after even though itll be rusty already
Mount intercooler
Remove radiator overflow bottle
Remove standard intercooler and save the bolts to mount new intercooler bottom brackets with also strut brace needs removing to get tmic off
Replace with new slimline one also bottom mounting point for old bottle needs cutting off to fit intercooler piping i had to cut the mounting tab and re drill hole
Fit pipes il add afew pics for refrence
The standard flanged dump valve wont fit onto this kit so il be fetching a normal dump valve tomorrow and il add pics as this really stumped me for a while
Next was trimming the bumper this takes 2 hours easily to do correctly once again il add pics for reference
Put fog covers back on and grill
I raised my reg plate 2" purely for looks lol
Job done apart for dump valve tomorrow so il post when done.
Im in no way a mechanic nor am i saying this is how it should be done im just sharing how i found the install
Also the job took from 9am untill 5.30pm if anybody has any questions just let me no il help as much as i can also few pics i missed off
Standard top mount cowling removed
how pipe runs under induction kit
Removed parts pile
Also this job looks daunting but really is pretty easy if you have the tools and half a brain lol also a tea maker as its thirsty work 😉
Job well done their mate.when i fitted one on my blob i also took out the black part at top were number plate is to give more air on to intercooler.
What is the smallest reg plate legally alloud on the front?
And if you mean the tint stuff i had it professionally done mate so im not sure
Oooooor
If your feeling creative, knock up a bkt to go between splitter an bumper, and mount it sort of half way between(over the join) will also direct air into the fmic a bit, win win
