Knackered wheel bearing
So I've had bearing whine for a while, had the garage check it out back in September but they couldn't narrow it down as there was no play in any of the wheels. Now it is significantly worse so once I'm back from my holiday I'm gonna get it fixed.
It started not long after my n/s front caliper siezed on so I assumed it would be that bearing. Noticed today that the noise goes away when i'm turning right, but remains when turning left. I would think that a bearing would stop being noisy when the load is reduced? It's entirely possible that it is another bearing and it was completely coincidental...
it's a driver side bearing then, wheel bearing are more noisy when you load them up in a sweeping bend/corner, quieten right down when you unload them in a corner
Just need to listen to see if it's front or back
It does sound like it's coming from the back but was unsure as it's obviously difficult to pin point from inside the car...
Must be a coincidence then!
I've got a noisy n/s/r bearing with no play, an play in n/s/f with no noise
That sounds like a ballache...
Will be when I get round to actually fitting them lol
Going to do them yourself?
Will be yeah, do most of my own work
I fitted a new nsf on mine two years ago wasn't too bad, the old one was shot and sounded horrendous! Was embarrassing squeaking around everywhere, it was intermittent sometimes too so was misleading at first.
Do them in pairs anyway. If ones gone, the other side won't be far behind. I did both my fronts last year with a fried who has an hydraulic press.
