Under car treatment?
Just wondering what people thought was the best stuff to protect the underside of your motor with?
what about wax oil?
Or thay bitchumen stuff?
Any ideas?
I'll be using waxoyl on mine. It seems to be good stuff. Just make sure you use a power washer to clean off your area first. If you wanted to go all out you could use dinitrol.
Waxoil does tend to go everywhere, I've had bad experiences in the past I now usually use the hammerite under body seal to do the floorpan and rear arches, then get some rattle cans for inside the box sections and a few places you can't reach
Then get a couple of the
Just been reading in jap performance mag about a company called krown that use some kind of mist spray that attacks the likes of surface rust and basically gets underneath it to protect the metal. It eventually turns into a gel so never sets and doesn't fall off or get chipped so protects for longer. Takes about 4 hours to do a car. Not sure on cost though.
Sounds expensive tbh
Iv left the mag at work so I'll check the morra and see if there's any mention of costs. Apparently the Canadian army use it on there vehicles.
Gonna have my car done at some point, so interested in this
13quod for a tin of underbody seal and a brush, save your money by not seeing a specialist,
Wirebursh all loose crud, then prep the rusty bits then apply coat
Small cars start at £190 rising to £320 for larger more complex cars
Before
After
Lasts for about 3 years before needs doing again but much cheaper than paying someone to do much the same job 85b92fa626e80d6ba5532064952f0f2f.jpgc5d305cd6842be47a062174fd321ecf5.jpg
