So been trying to figure out this problem now...my rear tail light (running light) is out. Replaced the bulb, nothing. Checked with multimeter, 13.35 steady when headlights are on, 0 when ignition off. Left the new bulb in when I went out the other day and checked it when I got back, and the bulb was hot. It's only on 1 side that it's out (right) and the front fog light is also out on the same side of it makes a difference but I'm not overly bothered by that as I am getting fog covers anyway. However my MOT is due at the end of July and I believe the running light being out is a failure...
Hey bud. By you description maybe the connection between bulb holder and bulb is not very good or daft question, are you sure it's a 12v bulb and not a 24v? Just something to check
Positive is a 12V bulb. It was the original bulb in place when I pulled it. Looked a bit heated on the end, so I replaced it. Took it into a local shop and gave them it and they gave me the new bulb to match...
Have you checked where the bulb sits, sometimes there is a build up
Yeah mate, looks clean as anything...I'm honestly baffled.
From a mechanics point of view.....
Have you tried a hammer? Lol
On a serious note, the lower connection in that pic looks to be pushed in
Haha it's about it get the hammer!
Sorry which one in particular? Not very good with electrical stuff...how should I go about fixing? Screwdriver?
Right to follow this up. Switched the bulbs around, it's not the connection. It's the bulb I think...can't get it to fit in snugly.
