Anti-entrapment problem
Drivers door window goes up, then immediately drops 10cm. Have to lower it completely and then just nudge it up very slowly to closed. Even holding the up button with 6mm still to go causes it to close and then drop. This is a real pain in driving rain. Anyone know of a re-set trick ?
Not so sure about the windows in the xv but with alot of cars if you put the window down and hold the button for 5-10 seconds that should reset it on the downward side and the same for upwards, alternatively put the window down and push the button 5times then the same when you put the window up, hope this helps :smile:
Not so sure about the windows in the xv but with alot of cars if you put the window down and hold the button for 5-10 seconds that should reset it on the downward side and the same for upwards, alternatively put the window down and push the button 5times then the same when you put the window up, hope this helps smile.png
Agree with all of that. I used to be a car transporter and most cars have that as a reset.
Thanks for your suggestions. Tried them both but with no success. I can close the window, ignition off. Wait a while. Ignition back on. hold the up switch and the window just drops. Urgh !!!
