I've been looking at getting a straight through centre section for my 2006 hawk sti, to mate to my prodrive backbox. The main reason is so I can delete the big silencer and hopefully have a little bit more noise while keeping the subtle look of the prodrive unit.
I believe there is a catalytic converter in the down pipe and another between the down pipe and centre section. All the straight through centres ive seen are listed as 2001-2007, so replace the 2nd cat as well as the centre silencer.
My question is, if I replace this cat and silencer with a straight pipe, will the car need mapping straight away?
Ive read some conflicting opinions on this, people saying that as long as the up pipe and downpipe still have the cats in then it will be fine; while others say that it will need mapping straight away.
What's people's thoughts?
Me personally, I'd do as prodrive did and leave the one in DP and bin the rest. If I remember right, wrx has 3 cats, STi 2 and prodrive 1
@mattiekane cheers mate!
so as long as I leave the ones in the up and down pipes, it will be safe and legal to bin the centre one? 😁
Ur an STi, you only have two, buy a non res centre pipe and you will be fine
@mattiekane I see where your coming from, but; I thought the 2006 sti had a cat in the down pipe, then a small section between the centre and downpipe with another cat, then the resonated centre section then back box. All the centres ive seen are for 2001-2007, so replace the 2nd cat and deresonated centre. On 2001-2005 cars the 2nd cat and centre is one pipe.
My question is, is it safe to replace the 2nd cat and resonated section with a straight through section without having it mapped, as long as I leave the one in the downpipe?
I'd would of thought you would be fine,@Tidgy would probably know better tho
I think it's removing all the Cats is where the problems start, other option of course(to play it safe) would be full decat an map, then you know it's right regardless
Or buy a blitz lol
@mattiekane
my plan is to make it a bit louder, but keep it legal (I.e so it can pass an mot) and not to **** the neighbors off too much when I start the car at 5:30am and leave it 5 minutes to warm up 😂😂
i guess that pretty much rules out a nur spec lol
Sod the neighbors, Impreza's are meant to be loud and abuse the ear drums, imagine how mine feel at 6am lol and I have a decat waiting as soon as I can get a map on it
The last one in my downpipe but only when I can sort a map for it
@savage bulldogs I did think of that, but with the centre resonator still in place, the backbox alone wouldn't make s great deal of difference would it?
You won't need a remap as long as you're not touching the downpipe. I did this mod and ran it for about a year with zero issues, as long as you get a cat pipe section which has a hole for the o2 sensor you should be fine.
15 minutes ago, savage bulldogs said:
Prodrive boxes are renound for being 1 of the quietest boxes out there but ive never tried tbh
@savage bulldogs yeah it's very quiet. It sounds as though the cars cut out when you come to a junction it's that quiet, and it's not a great deal louder once you put the toe down.
Thing is though, I like the way the prodrive one looks on the car. I thought a straight through centre would wake it up a bit but I don't want any problems.
I suppose a subtle but louder back box would do the trick. What do people normally go for?
@Sandals thanks, good to hear👍
How much louder does does it make the car removing the centre silencer and cat?
Should in theory be ok if your not removing all the cats, but its always worth getting it dyno'd after to make sure all ok. Most cases its fine but no way to be 100% sure without checking
I was running a cat back straight pipe for a bit, that sounded awesome.....sometimes
@mattiekane
just bought a straight through centre pipe 🏎💥💨
Jesus, about time lol
Keeping the cat in the down pipe and keeping the prodrive backbox, but the mid section will be all business, milltek stainless straight through job. Not sure how loud it's going to be, but no doubt a touch louder at least 😎
Will probably sound well
