car will not start after cambelt change
quick swap of non working coil to working coil bank will diagnose if coil or wiring.
Does seem bit unlikely have 2 dead coils after fitting belt but if had removed them and plugs during your working session or knocked wiring then more possible.
I've pulled a few coil on plug packs and had them not working on refitting as extra movement finishes off a dying pack, hard one explain customer when comes in without fault :-) pretty common for issues are packs but need verify fault before start shooting parts at it .
Had odder scenarios happen lol .
Tested the packs with a multimeter there defo done in will be puting back together today or tomorrow so will let you know
Sent from my SM-G903F using Tapatalk
still didnt start :angry::angry::angry:
5 minutes ago, savage bulldogs said:
Have you had it running since you did the coilpack conversion or did you do that after the cambelt
yes been runing for about 2 years with them
2 minutes ago, savage bulldogs said:
Does it smell of fuel a lot when cranking ?
Nipped a injector o ring, maybe ?
Tps and both temp sensors making a good connection?
Not adjusted the icv or tps , while stripping it down ?
Does it smell of fuel a lot when cranking ?  = yes but only out the back end and it is getting fuel today it almost started on first tern over but the will only fire on the odd occasion when repetitive cranking
Nipped a injector o ring, maybe ? = never removed them
Tps and both temp sensors making a good connection? checked my esl dater and temp today was 11c and tps was at 6.5 and when fully open 78.
Not adjusted the icv or tps , while stripping it down ? = both of these where not touched
Thanks for your help btw
No problem bud, i like to do things myself and have a soft spot for the early classics .
Have you tried leaving the plugs out for a long time , letting the fuel in the bores and on the plugs to evaporate.
Did you fit bigger injectors for the remap and did you plug the maf in when trying the oe ecu ?
As unless a lot of time is spent on the cold start map when running mafless , it could be flooding due to the colder denser air affecting manifold pressure .
Hope you suss it soon , it's starting to make my brain hurt
still ruining a maf based map atm with the stranded injectors
as for letting the plugs dry iv not yet so will pop them out tomorrow and leave it alone
and so do i, i love the car and tbh it's way to different to any of the rest so dont want anything else
and my brain has terned to mush haha
On 27/01/2018 at 6:50 PM, savage bulldogs said:
I only had esl on my v3 uk , so unsure if the v1/v2 is the same but i had switchable maps . When i disconnected the ecu it automatically switched to map 1 , had to depress the throttle to the floor then turn ignition on to switch back to map 2 .
Bit of a long shot that it has switchable maps or that if it has , that map2 is useless . No one local got a standard ecu to try to rule out a fried ecu .
Fuel pressure reg vac line ok? , a very weak fuel pressure might cause it to fuel cut /cut spark .
Can't think of much else atm , hopefully it's something simple and not lack of compression.
I assume if you've got a copy of the service manual, have you checked everything electrical it says to check regarding no spark when turning it over?
On 24/01/2018 at 7:16 PM, Mr B said:
I would check timing followed by sensors/wriing as pretty sure it cutting ignition once reads sensor correlation off .
hi guys been looking about and have read that the timing can be put out by the thickness of the head Gaskets, now iv used 1.6mm and was told this is standard for a 1993 wrx by icp so 2 question have come up can it put the timing out that much it wont start and is 1.6mm right
Ive seen idle issues , like hunting due to the wrong thickness headgasket but that was on a na golf . a compression test should rule out wrong gasket thickness though [emoji6]
150psi on all 4
Think 140 to 170 is oe compression .
Strangely enough my mums nissan puke had the same symptoms today . Tried to start first turn of the key , then stalled and just cranks over . After talking to my brv , he had the same thing with his jap mx5 and it was a imobilizer issue .
So we tried her spare key which wouldn't unlock the car at but started the engine first time . I know you said the alarm wasn't operational on yours but its far too coincidental not to mention .
It good thinking but there where never an oe 1 fited and the 1 i fited i never connected so i dont think its that iv got a auto elc coming out tomorrow so fingers crossed
