Well as most of you know I've bought another another scooby project , yeah yeah i know i haven't finished the classic project yet [emoji849]
i (probably lol ) won't be keeping the bug and definitely won't be selling my 94 sti .
So a mate bought a low mileage, with 2 owners and good history 52plate bug wrx sti type uk about 2 yrs ago [emoji41]
Unfortunately a previous owner had hidden a mild crank rumble [emoji53] and even after spending a fair bit on maintaining and mapping it's gradually got worse . Although it's a nice clean example, it was probably worth more in bits than whole scoob with a knocky lump .
He didn't want to see it broken , so i decided to buy it and rebuild the engine , to save a fairly rare uk bug sti from the scrappy in the sky [emoji41]
I've decided to do this thread solely through tapatalk to save me uploading pics to my tablet , so you'll have to bear with the pics being on seperate posts .
So heres a couple of pics of the new edition to get started and i'll post more as i go [emoji6]
4e7db079a0251066ca75fbfa0c091b82.jpg06b56419a0b687e1fe53a3586d91e105.jpgf314321c5969ec9b1c1521e22ede07ec.jpge93b03a8fc70f9c9bf9e595f4e316fc9.jpg6ce92fc710054b6c2b19caa26a40a56c.jpg
It's got a few mods but i intend on keeping it standard as possible due to it only having 77k and 3 owners .
B.c coilovers .
Strutt brace .
Intake pipe .
Samco hoses.
Rcm lightweight pulleys and flywheel.
3 port boost solenoid.
Ecuteked bob rawl map .
And deffis ,but they might end up in my v1sti [emoji848] .
800 miles before i bought it the bug had some major maintenance done too .
Exedy clutch .
Graham goode uprated oil pump.
Full oe cambelt kit and new water pump and it came with a bnib oe raditor in the boot [emoji41]
Seeing as the bugs sti standard forged avcs engine is capable of 450hp i intend on keeping the build to a fairly standard spec too .
Made a start ripping the guts outta the bug
Tmic and air box removed 5fdbbaabae06a0d12e2522ac0e1adb5a.jpg&key=ee524b1e30e148d13e11810ad621d9cbcccf5d33336f8d0a78fb6ca3c4b6cfd89a4da64e2b633f154130899e6b27c653.jpg&key=369c040c96a87d5773c3c32de40e39b77d8cfda31214cd13bdbb5c5a6b18c33d
I left it overnight once the Rad and downpipe were disconnected as i wanted to do a compression test and check the bores with a endoscope before removing the engine [emoji6]b0c49ad54d66e678c75060c918f68cd3.jpg52712a47b36d3cb93c741d65ce6ac927.jpg
The compression test came back ok with 133psi across all cylinders [emoji41] but due to the depth of the heads , all i could see in the bores was the piston sizes ie a or b , which is pretty usless seeing as that info is already stamped on the top of the block[emoji849]
Guess i'll have to wait until the heads are off to see bore condition, then [emoji23]6ffc1b60e32924bad93d42c0b5931080.jpg8a12229338a08227d93adf4e3fbde42a.jpg
Once I'd removed the clutch fork pivot pin, any remaining coolant pipes, vac lines , fuel pipes , gearbox and engine mounting bolts. I took the p.s pump off the block with the p.s lines still attached , so i didn't get oil everywhere or have to refill /re bleed the p.s system .
Once the engine was out i removed the new clutch so i could fit the engine onto the engine stand . c2c9bd9ad28edd57a60a99f40714aaf9.jpgfdac2a6360df2e7c0dbf77eb3316ed3e.jpg
Removed the coolant tank and air con pump , then disconnected all wires from the engine loom to the block and took note of all oil breather pipe routes . Kids old paddling pool has been a life saver , mrs would go skitz if i got oil on the patio lol c7939cfccaa68b772f8a2d153b97840b.jpg&key=e42614199aa542fe8c6b75ef811b93a367d3236b61f1731ea706c550005127bd718570d56df7484cc6aba80e1ae9f976.jpg&key=32ca02d8b1e79327bc01a786327bcd0199ab90e73a4d4308e3213c5ab5ddbcf7
Ive only spotted the 1 minor oil leak from cylinder 1's spark plug to cam cover gasket and a fairly big leak from either the oil separator plate or rear crank seal (i'll get back to that a bit later ) otherwise it looks like its a 77k fsh lump .cb63da5730ee6bc1324e462d6968996d.jpgd7840516ec157498d66f57d353d483f3.jpg
Basically once everything that connects the inlet to the block can be unplugged , then the whole inlet with fuel rails, injectors , engine loom ect can be lifted off in one piece.
Removed heat shields,to get to the head exhaust outlet studs and took the headers off , then undone the turbo coolant and oil feed /return pipes . Removed the turbo , turbo support brackets and up pipe in one piece too .popped the cambelt covers off to have a peak at the avcs pulley set up before lunchtime .e1f5a086fbcca95a6c17ca4e84419818.jpg&key=d17bde0271e3a95270fcd4b12a5a996834ec53f1710fbfa50479048bb1ceaf3a13a904910011ad13f2992f1867ff2581.jpg&key=61f44eb2817fdc7e7f5918b3a7edb2fa668b9bfb66e23d904800b12a5f716c70e9b56c5832fda3da6c02ce7a2a182c9e.jpg&key=96a8ba6cb778f0547f2abe9aad03c592d0edaf31c9fef358126aa77f39dfa3df
Once the engines fitted and run in , take it to attowes and get the map tweeked /dyno health check . take it to a few shows early summer and work on the v1sti's whilst its off the road .
When i sell it probably depends on if someone offers me the right money , to cover the car , build parts and my time .
Expand
Hopefully by then I'll be in a position to get back into the Scoob game :D
Hope so bud , i hate not having boost n burble in my life [emoji53] .
I've got 5 people intrested in the bug already and i haven't even got the block to the engineers yet .
Best pull my finger out [emoji23]🤣
Locked the flywheel to remove the crank pulley and center cam belt cover , which shows the new full belt kit , water pump and uprated oil pump [emoji41]
Unfortunately, i forgot to take a pic of the cambelt locking tool you need to lock the left bank pulleys to remove the belt without letting the left bank pulleys move . Once the belt was off i removed the 4 cam pulleys and the cam covers to expose the cams .189a3a3aa4c2ba3222ea06cb42e9b813.jpgd26ef8848298bf3e954130f9d5b6dd29.jpgeba8244608c29f3b23cc59bad1dbb372.jpg
With the cams , pulleys and avcs solenoids out you can finally get to the head bolts and remove the heads .
Its a semi closed deck block and the bores are in that good a condition that you can still see the original hone marks . Not that a visual check is enough to ok the bores but its good to see that it was obviously the original 77k fsh lump [emoji41] 02c325be93eb8f03e4a13ce994baf91f.jpg02495957c8eb614e817c364669a21a8f.jpgd0cebb5a9c89e1bb1f099733755048b8.jpg
  • Like 3
Once I'd removed the rcm lightweight flywheel i could see the oil leak (i mentioned earlier) was coming from the rear crank seal. It had obviously been leaking for a while . It doesn't make sense to me why it wasn't replaced (or at least cleaned) prior to flitting the new clutch [emoji848]
Good possibility that the leak being so close to the rear crank journal would cause a dip in oil pressure or oil level at some point . Which might have starved the main bearings of oil and caused the crank rumble in the first place .
Cleaned the back of the block , took the sump off and spotted my first bit of fubar'd bearings stuck to the side of the oil pickup 436857d792982e82702c1b941f58a3db.jpg0e05bc34b115c6d89940a0170aa6c26a.jpgdf959be2fec159fc852fae288ae9b3f9.jpgfe346ad2879699c6934564612a7c4759.jpg
You had to remove the access bungs to get to the wrist pin clips , take the outter clips off the wrist pins ,then use something long (que bbq skewers [emoji4]) to tap the wrist pin out from the other side .
As the bottom of the bores have "webs" which mean the pistons have to be disconnected from the rods in order to split the block halves to get to the crank [emoji6]af2504b9a51da29262466c2b116670df.jpg67ce706429578d0e27f5f3bb33ad0980.jpg9db137da0c3123948bc670f04e7a35ba.jpg660be5e58c22720646a2375f41d6d9ce.jpg
Once I'd split the block and removed the crank the cause of the rumble was plain to see ,fubar'd main bearings .
Although the bearings had taken the wear and the crank measures up ok , i won't be taking any chances and will be fitting a brand new crank [emoji6]25ace1b869ba92bbc1ac3b53791a635f.jpg67ffb8843e40df55e92c6818ca438e40.jpg
Luckily I'd pulled the engine before the beast from the east dropped a blanket of snow in suffolk. Having another scooby came in handy , as the snow didn't stop me dropping the block halves off at pat segars (my trusty engineer) [emoji4]
I'd originally planned to leave the heads in one piece, due to them being quiet and the engine not smoking , so valve stem seals and seats were ok . But the urge to fully refresh the engine took over and I've decided to (at least) re seat the valves and fit new stem seals [emoji4]
They'll also go to the engineers for a pressure test and a general check over once i collect the block halves [emoji6]
Block half faces have been checked over, bores have had a light hone (to bed the new rings in) and the pistons have come up well .
Looks like im gonna have to start getting my shopping list together soon [emoji4]0615e3c199da2f1a8ff9923b7815662a.jpg
  • Like 4
The avcs Heads have the usual visual crack between exhaust valve ports and spark plug hole . Although it's almost impossible to find a second hand set of avcs heads without cracks (very common issue) and the 3 other scooby engine builders ive spoken to , said they looked fine .
I dont want to take any chances so i had my engineer pressure check , lightly mill the faces and recut all the valves in both heads . Which cost me a extra £300 on top of the normal face work [emoji849] but it's worth it for piece of mind for me .
Looks like I'm starting to run outta excuses not to upset the wife and order all the rebuild parts [emoji4]
Great write up so far buddy those heads look exellent you'r engineer has made a really nice job of them, when is the rebuild starting? 👍. I've just started to rebuild my v1 engine so should hopefully be back together and back in soon then a quick mot and off to see mr forrest for a map 😁👍
Still haven't ordered the parts yet as im getting AS performance, icp and R.M performance to quote me and price match first . So I'm not too sure when I'll start just yet ,As i need to keep costs down but won't cut corners [emoji6]
I'd originally planned to get it fitted and start the running in process by the end of April but as it gets closer to the warmer months i tend to get a higher work load and struggle to find spare scooby time [emoji53]
Could always just turn my work phone off until may [emoji848] [emoji23]🤣
Thanks for the comments chaps , hopefully this thread will help familiarize members with the ej207 and give the new owner piece of mind seeing it's been built properly .
Finally Ordered the build bits this morning so once they're here and everything has been through the engineers hot wash again , i can hopefully crack on with building the engine [emoji41]
Due to the rear crank seal failure the bay and gearbox bellhousing are quite oily , I'd been putting of cleaning everything for a while [emoji849].
But after a couple of hrs and nearly a bottle of machine cleaner , not only does the bay look a bit better, but the new clutch has got a much better chance of not being contaminated by all the oil [emoji6]
