robert davies Posted November 25, 2018 Posted November 25, 2018 has anyone fitted an omex rev limiter on their car. i have fitted one and cant get it to work. dont know if i have wired it up wrong to the coil packs. there are four wires. red. black. blue and black with a blue stripe. i know the black is positive but dont know what the others are.
mattiekane Posted November 25, 2018 Posted November 25, 2018 Yes, don bother, it's a pita, dosent work right(pushes through the limiter) buggers your lambda sensors.Loud pipes save lives
robert davies Posted November 25, 2018 Author Posted November 25, 2018 is there something else on the market that will do the same thing.
mattiekane Posted November 25, 2018 Posted November 25, 2018 Yeah, wait till you get it remapped and get the mapper to-do it [emoji16], it's a 100% better optionLoud pipes save lives
Tidgy Posted November 25, 2018 Posted November 25, 2018 What are you trying to achieve? the ecu controls everything, no need to run anything else untill you get to the point of running big power. All this bolt on crap is a waste of money and half the time damages the engine.
robert davies Posted November 26, 2018 Author Posted November 26, 2018 trying to get it to pop and spit flames
Tidgy Posted November 26, 2018 Posted November 26, 2018 can be mapped into the over run, also its not great for the car
Geoffpalmeruk Posted November 26, 2018 Posted November 26, 2018 17 hours ago, robert davies said: has anyone fitted an omex rev limiter on their car. i have fitted one and cant get it to work. dont know if i have wired it up wrong to the coil packs. there are four wires. red. black. blue and black with a blue stripe. i know the black is positive but dont know what the others are. I think it depends on the model of Revlimiter you have. The ones i have see have the following: Red - Coil Positive (power) Blue - Coil 1 Negative Blue - Coil 2 Negative Black - Earth. (some come with an extra cable - Orange - Remote button) Also if you want it just for pops and bangs, i heard it is best to remove the cat 😛
robert davies Posted November 26, 2018 Author Posted November 26, 2018 its the wires going to the coil on the car i cant work out. dont know which wires do what.
Geoffpalmeruk Posted November 27, 2018 Posted November 27, 2018 is it single coil or dual coil omex you have? This might help? http://www.clubsub.org.nz/forum/index.php?/topic/45463-v5-6-wasted-spark-wiring/ Failing that i would speak to Omex. 1
mattiekane Posted November 27, 2018 Posted November 27, 2018 Omex will tell you the same they told me, Subaru is not supported by them and the unit dosent work on themLoud pipes save lives
mattiekane Posted November 27, 2018 Posted November 27, 2018 You can hear it here on mine, even tho the limiter cuts in it pushes through.If your determined Todo this then the 2 wires for the coils you have a splice into with one way diodes then join them togetherLoud pipes save lives
Mxngobby Posted July 16, 2019 Posted July 16, 2019 On 11/27/2018 at 10:23 AM, mattiekane said: You can hear it here on mine, even tho the limiter cuts in it pushes through. If your determined Todo this then the 2 wires for the coils you have a splice into with one way diodes then join them together Loud pipes save lives I’ve seen the YouTube videos of the omex working on yours, any chance you could draw a diagram of how you wired it up to work? Or a video demonstration of the wiring maybe TIA
Bowman7820 Posted February 26, 2020 Posted February 26, 2020 So does any one have a diagram for wiring up the omex to the Subaru?
Register a new accountSign in
