Power
Hello, I have a Subaru wrx prodrive 2004 , I have installed an sti intercooler, sti turbo, performance radiator, stage two clutch and fly wheel and a full de cat exhaust system including headers . I am going to get it remapped soon along with installing a fuel pump (aem 320lph high flow fuel pump)
I was just wondering what sort of power I would achieve
  • Replies 51
  • Views 7k
  • yep, modify it right or it will blow up in your face. Also people seem to think becuase they can buy it for 5k, its a 5k car come service time, no its a 30k car come service time
Is that wheel horse power ?
I also have the prodrive so it already has an update ecu , what difference would that make on the remap ?
What upgrades do you need to do to get it to 300 hp?
as I have the full 3 inch exhaust system along with the headers and the sti power parts more or less
Assuming the STI turbo is a TD05 should get more than 300?
Thank you , I was thinking that too , I was a little disappointed with 280 ish hp.
how much power do you think ? as I’m not sure if the stock wrx injectors would support it
Ok thank you, having this power would I need to upgrade the injectors or just the fuel regulator?
also: I was also considering a cobb inlet , would that be any good?
Ok thank you . Do you have to get the fuel regulator 😂 or can I survive on stock ?
The company that do the remap should know the limits , so hopefully they don’t mess it up . What’s the consequences for a lower fuel pressure or the injectors not good enough?
whos mapping it?
really bad as engine will lean out, but decent mapper will see it and stop the run. At that point its a choice between getting what you can and backing off the map, or swappng parts
oh not good then
I can’t think of the name but im paying around £450
Would I be ok if I get injectors and have an upgraded fuel pump or would I still need the fuel regulator ?
If so what regulator or injectors would you recommend as I’m a bit tight on budget
Its Being mapped on a rolling road and I think it’s going on the dyno.
oh, so the sti injectors should be good enough then , so I won’t need a fpr?
Ok. Would these be good to just fit if they was the correct fitment, or would I have to get them fitted by a machanic ?
Ok thank you , Is that the same for the fuel pump ?
Also would the remap people fit them ?
