Legcy MKIV Estate 2.0R auto Gearbox fault
Hi guys
I had the garebox serviced last year on my 122k mile 2006 Legacy but they changed the service filter not the internal one. The box has never changed up very well and at times is jumpy now and occasionally feels llke it wont move then suddently off we go. I was thinking of doing the inernal filter, service filter, ATF oil again. I'll use genuiene Suby parts of course.
The pan sealant is hard to get in this country.
Any thoughts would be welcome.
Cheers.
Derek
Do you know what atf fluid was used and are you sure the fluid level is correct?
H Greenmaba.
Thanks for the reply. It was done at the local dealer so I'm hoping they used the right stuff. The level is correct.
The service history was good up to 6k then patchy up to 100k.
its been great until now. It has the rusty bulk head bit done last year and I've had 4wd system and service done.
Cheers
Del
@Delek - the service invoice/receipt might state what they used. You do know Subaru atf level is checked with the engine running, in Park?
Thanks Greenmamba. I'll double check that.
Regards
Derek
Check your auto box before taking the pan off as it might not have an internal filter - I was all set to do the same to my 2.0r auto impreza and discovered there were x2 types of auto box.
Many thanks guys
Cheers
Derek
