Pommy Posted February 21, 2014 Author Posted February 21, 2014 Was closer to £100 after delivery and VAT was added on, but then I ordered it yesterday afternoon and received it at 930 this morning so quick quick service. Don't think it is genuine Subaru though, is silver and says WRX Pro as you can see in the photo's. Old calliper off the car with the disc stuck on, took some force to get it off and then some of the calliper in general and then the new one all put on. Admittedly not the best photos but you get the jist.
Mr B Posted February 21, 2014 Posted February 21, 2014 Yeh having seen some of those I would say they are copies as machining finish was bad on set I had a look at.
Gambit Posted February 21, 2014 Posted February 21, 2014 I've seen them on http://brakeparts.co.uk/ deffinetley copies or an aftermarket part. But couldn't tell you how good they are as a caliper.
Jay762 Posted February 21, 2014 Posted February 21, 2014 Cusco will have work cut out with the original :D 1
cusco scooby wagon Posted February 21, 2014 Posted February 21, 2014 the wrx/pro are copy's by budweg i think and are sold by Brakes International too, there ok. but feel a little cheap nothing replaces an original item, and the photos of the old 4 pots is to be expected ive had some worse than them but after a session in my blaster and powder-coated and lacquered they look a million times better it just takes a little time and effort on my part to get them looking like this ( ) 2
Gambit Posted February 21, 2014 Posted February 21, 2014 Well when you look at them old ones and those newer ones they look spot on :D
Jonny b Posted February 21, 2014 Posted February 21, 2014 Yeh have to say looked at these! When googling! Wasn't to keen tbh, but then they have to be made to a certain quality criteria! Just don't say subaru lol
Pommy Posted February 21, 2014 Author Posted February 21, 2014 I also think they are a bit heavier which isn't a shock, or this could just be me imagining it. But I needed the cheaper option as I haven't been paid since before Christmas (had to leave job to go to Aus) so am running a little low. I personally think it looks better in silver, although at the moment one is silver and the other one is red.... will hopefully get a chance to change the discs and pads on the passenger side tomorrow morning and see if there is any noticeable difference between the genuine and not so genuine. Although this !Removed! rain makes it hard to do any job, started the caliper in the sun today and ended it in pouring rain.
cusco scooby wagon Posted February 22, 2014 Posted February 22, 2014 I also think they are a bit heavier which isn't a shock, or this could just be me imagining it. But I needed the cheaper option as I haven't been paid since before Christmas (had to leave job to go to Aus) so am running a little low. I personally think it looks better in silver, although at the moment one is silver and the other one is red.... will hopefully get a chance to change the discs and pads on the passenger side tomorrow morning and see if there is any noticeable difference between the genuine and not so genuine. Although this !Removed! rain makes it hard to do any job, started the caliper in the sun today and ended it in pouring rain. there shouldn't be any difference in stopping power unless the original one is not working 100% which wouldn't have been noticeable at the time prior to getting the newer one on.
Pommy Posted February 22, 2014 Author Posted February 22, 2014 Yeah there shouldn't be any but will be interesting if there is. However we will have to wait for a decision, went to change the discs and pads on passengers side and managed to round the top 17mm bolt. The bottom bolt came off with a bit of pressure, however the top one didn't, so I used plus gas, cleaned it off with a wire brush, more plus gas and waited 10 minutes, went back and still no movement in any direction. Repeated again with plus gas, went to move the bolt and it just rounded off, will be off to RH on Tuesday hopefully so they can wack it off for me and then finally might be able to get the !Removed! thing off!!!
Pommy Posted February 22, 2014 Author Posted February 22, 2014 Well this story gets even better. Now the passenger side caliper is seized!! When trying to get it off today I did notice one of the ales was torn so had a feeling it was on way out. I think it may have been seized for a while but seized while not putting pressure on the pads. However maybe when bleeding the brakes the systematic pressure forced it out a bit and stuck it there. So time for another caliper change.
Jonny b Posted February 22, 2014 Posted February 22, 2014 I changed my front pads the other day did have a seized piston on one side! But the pads were really low!! Free'ed up the piston but seems fine on the new pads, just wondering if the pistons have more potential to seize the further out they are if that makes sense!
Pommy Posted February 22, 2014 Author Posted February 22, 2014 All the pads are in good condition with lots of pad left. Only trading in because they're budget pads and I value good brakes when driving enthusiastically!! 1
Jonny b Posted February 22, 2014 Posted February 22, 2014 Ha ha looks lιke Iam in for ιt soon then! Lol, yeh I agree
Mr B Posted February 22, 2014 Posted February 22, 2014 could get another copy wrx pro calliper then at least you got a paired set, keep the originals as you may want them fully reconditioned with ss pistons for future use ...
Pommy Posted February 22, 2014 Author Posted February 22, 2014 They are a diddle to change assuming your bolts come off easily Jonny. Me B I am talking to Cusco about reconditioning and getting one done the same colour. Then when I get the cost I can weigh it against the price of the WRX Pro one 1
Gambit Posted February 22, 2014 Posted February 22, 2014 I'm waiting for a price too :) But i did warn him i would try push work his way when possible ;)
Pommy Posted February 23, 2014 Author Posted February 23, 2014 Found the WRX PRO caliper on eBay from brakeparts.co.uk but cheaper than their own website!!! And free delivery for Tuesday.http://www.ebay.co.uk/itm/SUBARU-IMPREZA-inc-WRX-TURBO-LEFT-FRONT-BRAKE-CALIPER-4-POT-BRAND-NEW-BCA2882A-/261286155112?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cd5de5368 Seems odd to me but there you go.
Gambit Posted February 24, 2014 Posted February 24, 2014 Always makes me wonder how they can sell it cheaper on Fleebay than there own site. by the time fee's are added
BlackBosh Posted February 24, 2014 Posted February 24, 2014 Maybe if they've got some card company that has more expensive fees than eBay so they try and encourage eBay purchases? Just a guess. What's the deal Cusco with exchanging/refurbishing calipers? What's the turnaround? Price? I'm not in a hurry to do it yet but have some time off coming up, and my car can go for as long as needed on stands Sent from my iPad using Tapatalk 1
Pommy Posted February 24, 2014 Author Posted February 24, 2014 Yeah, I guess they could be charged more for card use than on eBay. haven't heard from Cusco over the weekend (maybe he has a life outside of Subaru ;)) so not to sure, I ordered mine online as I need them quickly, but still thinking on having the old calipers sent off to him, and then having them refurbed as spares or just selling them to him. Heard good things about him though.
Mr B Posted February 24, 2014 Posted February 24, 2014 Doubt it, eBay & paypal got to be more expensive than card payments from my experience, would assume low on eBay due to price competition between sellers.
BlackBosh Posted February 24, 2014 Posted February 24, 2014 This mans talking sense i was purely guessing
Gambit Posted February 25, 2014 Posted February 25, 2014 I've PM'd him about this and waiting for a reply I'm guessing not cheap as the 4 PM's it's been skirted over :D I know mine need's doing but trying to workout the price for the calipers along with a new front part of a hub and bearing AGAIN! :( and new discs and pads all round I would like to do it all in one go save doing it in bits but need to know prices, as i'm going to mainstealers for a new hub and bearing this time and don't really want to have the car off the road for long if it can be helped :)
Pommy Posted February 25, 2014 Author Posted February 25, 2014 Mr B does seem to have put some logic into his thought. And Gambit I have had the same thing with Cusco, so I'm guessing not too cheap either!!
