Hello from Manchester
No the tf035 is correct turbo they was fitted to all UK Foresters and yes it's only a small turbo :(
I can't understand why such a small turbo for the size of the cars  :wacko:
  • Replies 93
  • Views 8.8k
  • Hello welcome, just come across the thread sorry been busy, If it's a uk car it will have a td03 as stock, Imports have to04's Pop the bonnet and have a look do you have the coil pack off centre an
  • Download an app called "mycarcheck" slap your reg in and it might tell you the rough bhp of your motor :) not sure how accurate the app is tho Sent from my iPhone using Tapatalk
    If it's a tdo4 or tdo5 the id will be in the same location as in this pic Sent from my GT-I9300 using Tapatalk
Vf35 maybe ? Wrx's had these maybe visit a subaru specialist in your area investigate more
Sent from my SM-T210
Impreza wrx had td04, it was the sti that had the vf35 or td05
Cheers dave :-D learn something every day, & there's me getting the mans hopes up of a bigger turbo :O
Cheers dave :-D learn something every day, & there's me getting the mans hopes up of a bigger turbo :o
It's one of the best things about being on here something always new to learn :)
Its ok im changing the turbo very soon anyway.Its got a little whine coming from it and I don't see the point of fitting the same turbo again lol
Gonna be realistic and get a tdo4
Loads around and cheap, I'm happy enough with mine
Why are they so cheap then
Loads of scooby owners wanting bigger turbos so plenty of 04's around.
Ash had a pair he was selling on here a while back
Anyone now how many cats the Subaru forester has? I have a leaking exhaust looks like its been there since day one lol.With the weather being rubbish I haven't had chance to find out exactly where the leak is im suspecting its the down pipe from the turbo to middle section im not sure how many pieces the down pipe comes in.if its two pieces the cat will stay and I will just replace the worn out section.If not I will decat the the whole down pipe.
Here you go mate :)
Forester-intake-exhaust-diagram_zpsa7d1d
I tried sticking my head under the Scooby before and the leak was miss leading it could even be the down pipes from the exhaust manifold.Gonna have to wait for dry weather :( do the down pipes from the manifolds come in two pieces? carnt tell in the diagram
Thats the stock sf setup. The diagram gambit's posted is for the newer cars, we don't have the o2 sensore in the up pipe
Cheers mate I think its the middle piece that's gone.I will confirm tomorrow.Whats your name by the way
No worries mate,
Name's adam
No worries mate,
Name's adam
Adam is the middle part of that exhaust in the picture easy to come across?
I have no idea, it's more than likely to be the same as the classic impreza, the up pipe and turbo back sections are.
Is yours looking a bit past it ? There is a heat shield on there so if that bits knackered may be worth removing it and checking the condition of the pipe it's self. May get away with removing it then heat wrapping the pipe
Randomly subaru exhausts tend to rust from rhe outside in.
Yeah im thinking its a bit past it.The ground is still a bit wet gonna have to wait till its dry to have a look :(
Im after a decat middle section for the forester now the last cat at the back can anyone help me find one on ebay or no if the impreza will fit?
Opps sorry I didn't realize damn and I have had that picture for so long waiting to use it :(
Ive ordered my decat pipe now.Done a lot of research to find out what fits.If it doesn't mr grinder and welder will be coming out to play
Turbo now sourced :D
Good news fella, what ither upgrades you got planned ?
Nothing heavy.Front mount intercooler,cone filter,tinted windows,different wheels,4 pot brakes,front decat pipe and a remap,dump valve,coil overs,Wouldnt mind hitting 300bhp.I want no more that's good enough for a daily runner.If I don't get it with a td04 I will bolt on a 20g compressor wheel and housing :D
There have only been a couple of people with 300bhp from a td04, its usually maxed at 280ish. Don't be too bothered about the max bhp, the td04 is a great little turbo, it spools well low down and gives punchy mid range.
