boost controller
Hi getting a greedy boost controller its a old type one just has dials are they good how do u fit them
Not set up right easy way to go boom mate
Wouldn't be silly with it keep it low do u know how to fit them
Fitted one to a vauxhall years ago
Don't know how to fit them but, I think they're good as long as you get them set up with a map to suit .
As the fuelling can be set up for max boost and you can always turn the boost down for every day driving [emoji6]
And of cause back up again for the weekend [emoji16][emoji12]
Sounds good savage its a early greedy one was it easy enough to fit matt
Look good couple hours as we did it from scratch , mine went into a daughterboard ecu
be better just getting an open source remap, as if you get it wrong or it boost spikes kiss goodbye to the engine, Greddy or no greddy they all work on the same principle of a Diaphram which will wear, soneone i know fitted a greey to his Pulsar 6 miles it did and he kissed his Head, pistons and Turbo good bye due to it being faulty.
May as well do it right mate. open source your looking around 400-650 depending on the mapper and for that witht he right mods you will get 270-280
Been offered one cheap so thought it would be good thing will look into that open map mines a ver5 import 280standard
Anyone no how to fit these or fitted one can only find guides for the newer lcd display ones ?
