3 port oil catch can?
Thinking of fitting one of these but i can only find expensive 3 port or cheap 2 port .
So can anyone recommend a cheap 3 port oil catch can with 15mm inlets ?
I'm not going to return it to sump so a cheap one that vents to atmosphere would be ideal
cheers clive
id be interested in one of these as well
considering the price differential I would consider modding a 2 port with either a T piece or drilling a 3rd hole
Think I've found a solution .
There's a 2 port one for under £40 with a breather filter .
The breather outlet is 15 mm as well so I can remove the filter and use it as a 3rd port
[emoji6]
I'll probably buy it later and let you know if it works when it gets here
Have you got any pics of the breather can in question.There looks like there is a lot of cheap nasty stuff on ebay lol
Couldn't tell you what the quality is like tbo , so I'm not recommending it .
http://pages.ebay.com/link/?nav=item.view&id=351117810206&alt=web
Just looks like it's been tig welded to a reasonable standard, magnetic drain plug and it's under £40 .
Yes matt I did think about making one but I've got loads to do and haven't got the time[emoji19]
I have already asked the seller what dia the "breather" outlet tube is and he said they're all 15 mm .
So it should fit , just need to work out where I'll fit it and how much 15mm I/d silicone hose to buy
