What's this?? help
Hi everyone, can someone enlighten me on what this is on my gf8 sti? Looks after market and says Rspec on it, got no idea what it is. Cheers :)
post-3097-0-32809800-1413464907_thumb.jp
Is that located near front wing above abs unit ?
Yep
Barke ballance controller ? Clutching at straws
I would say It's a manual boost controller
Looks like vacuum pipes are attached to it and the boost solenoid in the background doesn't look like the bottom port is attached to anything .
so id say manual boost controller ;-)
What boost are you running ?
Standard I think around 15psi, Bit of searching on ebay turns out to be a manual boost controller so well done, anyone know much about these? what can i do with it?
