hello from channel islands
no worries bud, hope it helps
  • Replies 142
  • Views 15.9k
  • these are our other cars    mine is the astra coupe  with full irmsher kit on it also wheels just fitted a sportex race exhaust to it also. and hers is the puma
  • like this
  • Exup1000  i doing everything prep work and spray  job  a mate just messaged me on facebook  saying he has a Subaru wrx full interior for sale gonna have a look tomorrow
been told the black box connected to my throttle body is  a helmholtz resonator
whatever  that is
yeh, people say the resonator box (thats the one in the wing area) is needed for the car t run right, mines not got one and most people that fit the aftermarket cone filters don't have one and mine and theirs all seem to run fine, all i can suggest is take it off and try it for yourself
Thats it as long as you dont sell on or throw away straight away you can always revert - also as you do add more mods some will work well with standard items and wont work as well with other mods so the more you get away from a standard setup you increase the chance of that happening
ok guys as im working yet again today late shift again
i been outside working on my car since 7.30am  just come back in
i removed the airfilter box from near the arch  took away that resonator box and had a pipe going to my air sensor and my cone attached to my air sensor
guess what  no difference in sound really   just more of a hollow grrrrrr  with a bit of  whine
so i removed all again and reverted back to standard setup and sounds better  than the whine and hollow sound
maybe perhaps its the wrong type of cone i have   i dont know
but cheers for help guys
no worries pal, some things aren't everybody's cup of tea, thats what make us all individuals ;)
some one told me today to remove the cat and ram a broom handle into it and then tap with a rubber hammer around the cat and all the inards will come out  and then it will be hollow.
replace cat and car will sound better
now this sounds funny but has anyone ever done it ?
I know people that have removed the internals by cutting the top of the cat open and then welding back up, this makes it look the biz for mot and stops the restriction in flow but still plays havoc with the lambda and still fails the emissions, you should also be aware that the internals of a cat contains platinum so if you do it keep the internals and go to a scrap yard
As for sound, it affects it the way a decat would really, as with a decat you get the odd pop and bang from the exhaust
over here we dont have MOT'S  so no probs there  but i dont wanna  ruin it
Ahhh right, I didn't know you weren't in the UK, it won't ruin it as such but I'd advise to either get it remapped to have the lambda/oxygen sensor deleted or get a lambda spacer off eBay and fit that, that way it will read like the cat is still there and not overfuel
ok cheers  i will look into all that
Just another thing to keep you busy on your day off now :D
well its been a nice sunny Sunday, so out i went to have a few goes at my car
fitted the mud flaps on the front only and finished off the primer on rest of car.
just a quick rub down just before i start spraying the top coat now.
i'm off in 1 weeks time for a whole week, so i hope weather ok so i can do it.
Nice job. And the mud flaps do help the look of the car :)
Looking good, one of the rarer sunroof models too
well the car had another bit of work done to it today
done the last bit of primer, also done mirrors and handles
and fitted back mudflaps
Nice I like that you are doing the door handles too. I see loads with that not been done seems like a shame not too. Think this cars going to look great wants it's done :)
i have noticed you have wheel weights in the edge of the rim, alloys are suppose to have stick on weight inside the rim, the clip on ones like you have will corrode the finish on the rim and make it go all funky, if you can i would take it to be balanced again and ask for the stick on weights
cheers for comments
yeah door handles look better in same colour also mirrors
when car has been sprayed white i will be re-doing the wheels and weights will be going on inside (stick on)  cheers anyway for comment
No worries pal, didn't want you to have a mint car and corroding wheels
well i finished work at 6pm and decided now i'm off for a week, time to work on the car
here's what i did in just 1hr
looking good so far bud, nice job
Making great progress with the car mate well done looking forward to seeing the end results already. I'm maybe more excited then you are :)
well start of my week off and did loads today
