Vacuum pipe not connected doh help!!!!!
Hi there all I've a 2.0 s turbo and a pipe has come off ite one of the small vacuum pipes behind the alternator, going off under inlet manifold on right side ..... Don't know where it came from , car runs lumpy and won't drive I'm gutted .
A diagram would be useful , thanks in advance .
Pic of my97 car shouldn't be a great deal of variations between years
Hi it's the pipe coming out of left manifold under spark lead heading off under right side manifold rear
A pic would be ideal as the vacuum system is fairly complicated and differs with each version .
It does sound like it's in the fuel vapour canister area .
Can you see it in this pic if you zoom in ?
The canister is the round cylinder bottom left (as you stand in front of the engine bay) with 3 vacuum lines on top
Cheers I will check, it doesn't help that it's plumbed for lpg so lots of pipes
post-3182-0-22091200-1424374297_thumb.jppost-3182-0-18979600-1424374336_thumb.jppost-3182-0-18979600-1424374336_thumb.jp
The pipe goes under the right side inlet manifold to where is the problem
If all else fails I can chase mine back for you ?
Yes blue thing connected to purge pipe , if you could chase it back would be great thanks
No worries give me an hour and I'll go take some pics for you
Right my engine is different my coils are in the centre, so maybe you have a v4/5? Based engine, I've chased the one that looks like it could be the same but it's a nightmare goes back towards the idle control valve housing then does a u turn under the manifold.
In there somewhere !
If it's the other side it runs to the electrics going into the boost solinoid
My coil packs are on top , I'm going to buy a bore scope and see what I can see . Fingers crossed I will be drifting by lunch
If it's this side
It's the middle pipe on the diagram savage posted up it goes to a denso module under the boost solinoid
Cheers
I've searched net but no vac diagrams anywhere , I suppose too many variations also lpg pipes add to my stress
648ef77cd383a3146e4ccf72f2ee7ab7.jpg ghetto photoshop!
So
Just my pennies worth here. Could you whip the intercooler off to give yourself a better veiw of where it could possibly go?
I'm in process of removal thanks
New vac pipes turned up today I'm going to replace all.
Still scratching my head lol
Any joy ?
Bought a inspection camera still no joy I'm thinking of ringing rac at least the fault codes will indicate vacuum fault .
