Impreza turbo 2000 uk
  • Replies 84
  • Views 11.5k
  • Scoobyghost
    Scoobyghost
    old system against New. on and looking lovely. Next jobs are new fuel pump and I'll have the panel filter ready for when I have it mapped. Should have added I have a 3 port solenoid ready to help co
  • Scoobyghost
    Scoobyghost
    Should be really added pics of the car too. I'm new to a build as you can see and that's why I was reluctant.
  • Scoobyghost
    Scoobyghost
    Finished on the rollers a little while ago. 211bhp standard, all I have changed is a 3" cat back with resonated centre and rear box. Made 234bhp and 231ft-lb. Dead chuffed! She done well for an old gi
Looking good :)
Both started our "projects" at the same time, will be interesting to see which routes we end up taking!
Cheers Chris. It'll be nice to see how they both end up.
I've just been trying to sort an exhaust blow. No joy. Fitted new gasket but the old downpipe is bent on the flange so doesn't sit flat. Its in on the 11th april for the decat to be fitted so it's a case of putty until then. I really don't like temp fixes.
Roger Clarke fuel pump fitted today. Nice and easy job really. Ran into one issue; my old pump had a blue and black wire running from the pumps feed which went to a black box/relay. Made a phone call to my mechanic and he suggested it may be a pressure regulator. Regardless I went on to use the old wiring instead of the new plug rcm supplied.
All back together and turn of the key...fired up perfectly. Not to suggest the pump would be faulty but more my clumsy sausage fingers breaking something. Let her warm up and went for a spirited drive up the dual carriageway and she runs beautifully. Now just a tense wait for 11th when the decat goes on and the 16th with Duncan!
Decat downpipe fitted today. Went reasonably well. Had a couple seized nuts but they soon let go.
The throttle response is crazy now and the sound is beautiful. The turbo is really distinct now.
I'm so hyped up for Thursday and the remap now I'm basically wetting myself.
Video to follow.
Tempted by decat too... Or sports cat. Remapped too.
BUT, I kinda want to save money and save for a Subaru Type R.............
Sounding good fella ! I wsd like you until the morning of the map then I was slightly pooping myself and crossing everything that it wouldn't blow up.
Have you got the silicone y pipe yet ?
What's yours a v5, 1999 ?
I ended up buying savages sti cooler with pipework included, as got fed up waiting for one to get made for the foz, was cheaper in the end. Think scoobyworld and the likes usually carry them in stock, or try viper performance as they are loads chaeper than everyone else as they make massive batches up at once
Boo I know it's only 1 chap in a shed pretty much. You just click on the pay pal link on the side and put in notes what you want making.
You looking for something else instead ?
Coils on the left of manifold as you look at it ?
Yeah know what you mean supposd your guaranteed by pp if nothing shows.
I emailed a couple of times, sent payment, about a week later I had a parcel arrive 1st class
Sorry mate I'm tripping out that's what I ment !
On loads of painkillers haha
No problem. I might look at changing the intercooler at some point to for both cosmetic and performance reasons. Any recommendations? Also will it need to be mapped in?
Mine was a direct swap v3 normal to v3 sti so no mods or map required like I say only changed it for the y pipe as they couldn't be arsed making me one. Spools up so much quicker now
Theres a thread in the engine section about i/c info it's a good read regarding effectiveness,
New age ones will fit with bracket modifications and I suspect they'll need mapping due to increasing volume of air.
