why are my breaks doing this?
Yes wrx. And that sounds expensive. I don't really have the money spare for much. Just want them fixed to a state they don't warp my disks and shake
Sent from my D6603 using Tapatalk
Yeah they're not cheap nor are the disc's and pads. :)
Think I will leave the upgrade fir this time and just get them fixed
Can get a Brembo kit for sub 400 if you look about
I'm just going for the Godspeed kit with updated standard calipers and bigger discs
May ask about Brembos
just need to be carefull its right fitment. but also the subaru brembos have a really crap offset so may mean wheels or spacers needed as well
I have the 17" team dynamic 1.2 I think they are. There seems a fair bit of space in them
don't assume chap, don't wanna see you spend a few hundred on the brembo's and then find they wont go on.
Yeah tidgy is right ! Forgot about that tho I think you will b ok with td wheels
No I wouldn't :) thanks for the advice by the way guys!
At the min there is like a 2 inch gap
afraid its not that simple mate, my old classic wheels had plenty of gap but still didn't fit.  know anyone with a 01-04 sti you could just quick try a wheel on?
+ 1 for googling if your wheels clear brembos
as my old 4 pots had stacks of room under my 17" rota boosts but due to the curved shape of the spokes, once I fitted the brembos and bigger dia discs I had to run 3 mm spacers to give enough clearance .
What pads are you running, same brand as before you had the discs skimmed?
If you do go for brembos either buy from a trusted breaker or make sure you ask the seller if the mounting threads/ bolts are good as well as overall condition
As they do tend to strip the threads in the calipers ,cos their made from ally. You can get the threads repaired (hellicoiled) but it normally costs around £100 for the set
i changed to brembos because grooves on the inside faces of my old 4 pot discs used to fill with brake dust and cause "warped disc" symptoms . I just assumed that I was pushing the brakes limits heat wise and the outer faces stayed cooler .
