I done a bit of research and found on clubwrx it is mentioned the actual size is 3.5mm. May be worth using 3mm and lube or go for 4mm and use some ties at the ends.
Also not sure of the pills diameter. If you change that section you want that snug.
Yeah. Ordered the kit and some extra hose. Scoobyparts not back till Monday so should arrive next week. Shall I drop you a message when they arrive
Happy days, no problem mate, the misses has given me the go ahead to go and play with cars [emoji3] so we'll arrange a time etc
They prefer it when we're playing with other people's cars rather than our own, it's cheaper [emoji38]
Well after I snapped a captive nut doing non essential maintenance she did ban me for a while [emoji3]
[emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23]
Hi Stants. Kit and additional hose has arrived. Ready when you are. Don't know what your availability is like. I am tied up Saturday but free all day Sunday and most evenings. How long a job do you think it will be
Hi mate, I'm probably free Sunday afternoon have to check with misses, in process of moving house at mo, evening wise only really Thursdays & Fridays I can do
As for time frame a couple of hours at least,
Sender and original sender into t peice above alternator
Somewhere down there is the oil pressure sender (loads of fun)
Boost tee'd into vac line from manifold
I'm allowed out to play any time after 1 on Sunday, do you have a garage ? No idea what the weather is supposed to be doing.
If not I have warm ish, dry and quite well lit area at work we can use
Brill. If we can do it at your work that would be great. I have a garage but it's full of crap and waterlogged at minute.
What does the oil pressure sender look like. I have one of the senders in pic 2 but just like a bolt with the oil pressure like the one in this pic
post-4160-145219584697_thumb.jpg. Is that right?
Sorry the pressure sender is in pic 2 it's the temp sender in the other pic,
Mine looks like this as all electric
Have you had a look at the kit you got from scooby parts ? Does the sender screw into the threaded bung ok ?
