Correct way to Install gauges
They do it in 4mm?
  • Replies 112
  • Views 12.7k
  • When you free ? If you want to take a look at mine sometime and I'll gladly help out with install mate
  • Well after I snapped a captive nut doing non essential maintenance she did ban me for a while [emoji3]
    On both my standard 97 UK lump and the forged lump (with a rcm oil pump) normal driving in the winter (5° outside ) my hot temps are 85° to 92°and idle @ 1.8 to 2.1 bar Bit of boost in the summer
Should do
I done a bit of research and found on clubwrx it is mentioned the actual size is 3.5mm. May be worth using 3mm and lube or go for 4mm and use some ties at the ends.
Also not sure of the pills diameter. If you change that section you want that snug.
Brill. Thanks very much
Did you order the extender mate ?
Yeah. Ordered the kit and some extra hose. Scoobyparts not back till Monday so should arrive next week. Shall I drop you a message when they arrive
Happy days, no problem mate, the misses has given me the go ahead to go and play with cars [emoji3] so we'll arrange a time etc
They prefer it when we're playing with other people's cars rather than our own, it's cheaper [emoji38]
[emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23] [emoji23]
What's the trade off....there's always a trade off lol
You get it in the ear from your missus instead......
I just don't tell her [emoji23]
Hi Stants. Kit and additional hose has arrived. Ready when you are. Don't know what your availability is like. I am tied up Saturday but free all day Sunday and most evenings. How long a job do you think it will be
Hi mate, I'm probably free Sunday afternoon have to check with misses, in process of moving house at mo, evening wise only really Thursdays & Fridays I can do
As for time frame a couple of hours at least,
Ok. Just let me know when's best for you
Can you send me a photo of your setup. It's all double Dutch to me at the minute
I'll post it up here in a min ☺
Sender and original sender into t peice above alternator
Somewhere down there is the oil pressure sender (loads of fun)
Boost tee'd into vac line from manifold
I'm allowed out to play any time after 1 on Sunday, do you have a garage ? No idea what the weather is supposed to be doing.
If not I have warm ish, dry and quite well lit area at work we can use
Brill. If we can do it at your work that would be great. I have a garage but it's full of crap and waterlogged at minute.
What does the oil pressure sender look like. I have one of the senders in pic 2 but just like a bolt with the oil pressure like the one in this pic
post-4160-145219584697_thumb.jpg. Is that right?
Sorry the pressure sender is in pic 2 it's the temp sender in the other pic,
Mine looks like this as all electric
Have you had a look at the kit you got from scooby parts ? Does the sender screw into the threaded bung ok ?
Like this?
