So replacement engine in and running. I'm thinking great get my car back :)
Nope garage gives car a once over every to check everything good.
After less than a year of owning it ( bought from jct cars near Rotherham)
5a8e411636c3d92c25b2a10e057eac02.jpgd1b5df7ce7565494f887cf96f50a14b4.jpgf6afa1bfb970b158564ae6926ff5b612.jpg5f1d69a5abc91b4f71ef70c9777366d5.jpg7058f72d051d662e95853fadf9dbc8da.jpg552a17587be1353b0614b7b51e99613c.jpg18d93ff08d96608d03bd2f32f889f758.jpg
Not getting it back just yet :(
Don't it just
Anybody any idea if and where u can get repair kits/beams for chassis?
Obviously 2 parts can just be replaced the u subframe and the frame underneath the rad
  • 8 months later...
Gotta love those UK roads :huh:
Breakers would be your best bet, the u Shaped frame is notorious for going it then traps the moisture between it and the subframe, another member has had exactly the same problem.
There are a few specialists who do the repair work. But the 1 I know is on south coast.
Sent from my SM-G357FZ using Tapatalk
I had the same in my blob with the bit under the rad and the c frame went to a scrapyard, cut one off another blob and welded it in, painted and waxoyled and all was well, just unbolted and bolted another c frame on, and replaced the whole front crossmember also with one off eBay, complete with steering rack, hardest but was the welding the bit under rad in
Just done my cross member (rack mount and engine mount) not a bad job to be honest, wound happily take on another :-)
Ok ok, don't rub it in ! Lol
Haha I didn't do the rad mount cross member thank god, had the c frame etc out, but with a decent welder I'd do it all quite happily :-D
