Cooling system problem on my hatch
Hi guys can anyone tell me why my car is gettin sludgefillin radiator up.its had a new rad on it and a coolint system flush before rad was fitted.now it just fills with brown sludge and no collant left in system.this is happening after drivin about 20miles
Why was the rad replaced?  Where you getting overheating issues before?
That happening in such a short space of time it not good and you may have a head gasket failure.  You can get sludge with certain types of coolant, so fist point of call is thoroughly flush and refill.  Monitor closely and hope its just the type of coolant.
Check your oil on dipstick and filler cap.
No other symptoms?
Head gasket? Some !Removed! sealant product used in the system? Incompatible coolant without flushing properly? What does it smell like?
What flush was put through it ? Best case is Could be a different type of coolant reacting with the new stuff and turning it to goo. Ethelyne glycol/oat reaction worst case hg ?
[emoji22]
i replaced rad becouse i snap't the drain plug off when i fitted my silicone hose's :bangin:,not sure what flush it was now its been a while and got rid of bottle got it from local motorist discount shop,just been out again and all coolant is in over flow bottle and rad full dry sludge which smells burned,theirs no sign of oil in the coolant or coolant in the oil,i will give the system another good clean out and see how it is,if still same looks like its going to sss to see what he thinks it is and hope its not major :sad:
If you had no overheating problems or loose of coolant before you replaces radiator and hoses this would point to one of three things or combination of all three.
Radiator, silicone hoses, coolant type.
I use halfords OAT 5 year pink readymix coolant and never had issues with silicone hoses or radiators.
@steveuk260i use halfords OAT ready mix't as well,will flush it again at weekend and give it a good clean threw and see how it is.
Does anyone recommend a brand coolant flush to use.what do you guys use.
I just use the hosepipe, and put about 40l of water through the system from top hose then I just re connect the hoses fill up with water run till warm and going through system, drain and repeat. I kmow it's not the best as not distilled water but not had an issues yet
I'm also fiitin my water temp gauge at same time,i have 1 of them addaptor that you cut top rad hose but didnt wana do that.is their somewere on engine to mount sensor.thing someone told me before theirs a spare bung over number 3 cilinder.
I'd cut hose mine works fine
thanks,sorted it now,i did use the housing for the hose was easy and works great,hopefully the old boy will be back to full health now,found the water pipe to the turbo was leaking,new clip on sorted that so sould not loose any fluid now,spent most the day flushing the system out,water was crystal clear when done,so will keep a eye on it over next couple days but fingers crossed will be ok,oil change in morning and he sould get a full clean bill of health again :smile: thanks for all help and advice guys :wink:
:sad: well car still on the sick.Can leave the car ticking over all day and temp gauges stay perfect but bit white smoke and water coming from exhausts,rev it and get more white smoke but coolant level stays same,go for a drive dont see any smoke and temp stays normal,come home open bonnet and overflow tank is over flowing,heater gone flat cold,will this be a head gasket problem,when i drained coolant their was no sign of any oil in it and when i drained oil this morning their was no coolant in the oil.i read on  a site someone with same problem overflow fillin and overflowing and was told it was turbo problem,any advice guys :unsure:
If the overflow is being forced out it's being pressurised. If it is head gasket most common way for Subaru to go seems to be exhaust gases entering cooling system. Did you have it sniff tested?
@Scoobyghost going to nip to garage in morning and have it done.
well verdict from the garage is the head gasket is shot,like you said @Scoobyghostit is filling up with exhaust gas and blowing coolant out the over flow,and to top my day of i was coming back went threw some road works were resurfacing road and manhole covers were high up,had to drive over them so went slow but still broke my lip spoiler in half,happy days :cry:
I feel your pain man. Big turbo build on the cards now then ? [emoji6] Hope you get sorted soon
Its not lowered steve n thats barnsley council for yeah,their fook wits.jay i have a build thread just means am changin order of stuff.was goin be brakes n suspension next but now its head gasket [emoji22]
