Looking for Advice on Injectors.
looking for some side feeds 440 550 650cc any help?
No advise ? Any impeticular reason?
I've visited a Roman fort in days gone by....
@Impreza hi, I think you need some advice on injectors?  Are you looking to upgrade your standard ones?  Are you planning a turbo upgrade etc?
What specific model of Impreza do you have?  Im sure we can help you but do need to know a bit more info :yes:
What car for? What year? And what are the projected power figures?
Hi Geoffleggy, I have a 92 Impreza ej20 currently rebuilding it, and slowly buying bits, I need some injectors to pair with my td05, looking for 320-350 bhp so thinking 440's which may max out so 550's will be better option but more expensive.
Impreza 1992 ej20 and looking for something between 320-350bhp
On a TD05 and 440's you'll get to circa 350bhp but you'll be on about the most for both.  You can up rate to the 550's but you'll be restricted by the Turbo after 350ish.  Id aim for a comfortable 340bhp with them and save your dollar :biggrin:
Yeah my mates got 440's for sale £40 or 900's for £100 but there abit extreme? I'll be buying fmic and I already have stage 4 paddle clutch, Bailey blow off valve and will be getting new intake hose, I already have a full coolant hose kit purchased.
Buy the 440's and send them to Injectortune or someone to give them a good clean.  They will be like new and you'll know they are 100%.
I assume you have a good mapper lined up for when everything is in place? What exhaust system have you got in mind, you'll want a decat in place before the final map to get the best out of it all.
I might be missing something but hopefully someone will jump in.
Heard lateral performance cut change there spray patterns, area 52 in Nottingham, and I have straight threw blitz nur spec r system
Sounded awesome when it was running on 3 😂 So carnt wait for it to be built now
Once running wide arch kit will be a must have
Be for sale sometime in May
Yep need somet economic so after a 335d 😂
335 aren't that economical
320d m sport is
Better than 12 mpg on a motorway run I'll get 30 in 335
Pretty standard spec Scoob should see mid to late 30s
i couldnt get on with the auto box on the 335
what car you driving to get 12mpg,a range rover or lambo or something :unsure:
late model forester 2.5 XT has 565cc injectors
