Posted
HI guys
I have a subaru impreza turbo 2000 1999 it is currently stock just has 450cc injectors.
I was considering modifying the engine so purchased the following items.
VF 28 turbo
STI top mount intercooler
already has 450 CC injectors
i believe all it needs is a remap If anyone knows any cheap and cheerful places im all ears.
Cheers
Posted
1999 will have 440 injectors as standard. not worth swapping to 450's, if you wanna change em then need to go to 550's
o also recomend changing the spark plugs for 7's and also the fuel pump
Posted
You def wont need more than the 440's so thats cool.
Im not sure whos local to you but are you looking to squeeze the nuts of it or are you looking for more moderate gains?
Posted
depends on budget and what you want to achieve ?
do you want launch control / anti lag etc or just a basic system?
Posted
Cheap and basic options
- Eculabs
Cheap and no options and more expensive than above
-ECUTEK
Stand alone and easy to map
- Apexi
More functions and pretty good system
- Alkatec
mega money and really really good system
- syvecs
Posted
I am looking to gain what I can from the mods I have listed if anyone has any clues what bhp can be achieved. As for launch control and anti lag etc I don't think I can have that on the standard ecu so looking for something cheap and cheerful. looking for someone who can do a remap and if possible swap the turbo and the topmount  aswell?
Posted
Was on about 8 months with no dump valve tho and a lot of abuse !
vf28 is a good turbo
Its its a strait swap over those inter coolers takes about 20 mins
Posted
Was it a brand new vf 28 turbo?
Yes i thought it would be for the top mount. Do you have anyone that can do a cheap and cheerful remap?
Posted
Dyno is extra , you don't need dyno at that level
basic is just a map , no anti lag , multi map etc
Posted
It would be nice to know how much bhp car has Britt and after.
any places to do basic remap for basic price?
Posted
A power run is about £70 around me. You could get a run before fitting the turbo + parts. Duncan Graham is usually at surrey rolling road and does ecutek remaps + dyno for around £550 iirc.
Posted
before hitting the dyno - factor in cost of a good service, oil, filters, plugs (with gap set) etc also check when the last time the fuel pump was changed - if it is the original consider a replacement, what state the coil packs are in. Point of note you can have a great engine ruined by a bad map so I would approach 'cheap and cheerful' with caution
Posted
As Matt says - dynos are a reading of what the car is doing at that time in relation to the ambient temperature etc - so many factors affect the readings and the same car can differ day to day - but what you will achieve irrespective of the final power figure is a car matched to the physical changes you have made.
Posted
I have all the service parts engine oil, sparks are done, diff oil etc. I have even bought my own jack stands to do it myself.
A remap for £400 where is that?
Register a new account
Sign in
