Hirschhs Posted July 5, 2016 Posted July 5, 2016 Hello just popped in to say 'h'!. Living both in Hungary and the UK, needed something for the harsh winters and the steep hill we live on i Northern Hungary so just bought an 04 Outback Legacy H6. I have no info on this model so am learning as I go but it seems to be a very smooth and torquey engine. Is there a Haynes or equivalent workshop manual? I have the handbook...
GeoffLeggy Posted July 5, 2016 Posted July 5, 2016 Welcome! Sounds like an excellent choice . There is a Haynes manual for all models, easiest bet is eBay.
Hirschhs Posted July 7, 2016 Author Posted July 7, 2016 thanks for the welcome. yes, I love it. The H6 seems to be a fabulous engine. Are there people here who sell spares? I need an a/c pump or is eBay still the best bet? best wishes steve h
Greenmamba Posted July 8, 2016 Posted July 8, 2016 What makes you think the ac compressor needs replacing? Those things are very robust.
Hirschhs Posted July 8, 2016 Author Posted July 8, 2016 I hoped it just needed a gas recharge but the mechanic who checked it noticed that the belt was not turning the pulley on the compressor, it's kind of seized though can be pushed round by hand. Does that make sense?!
Greenmamba Posted July 8, 2016 Posted July 8, 2016 When you say the belt wasn't turning the compressor, do you mean the belt was actually slipping on the outer rim of the comp (where the grooves are) or do you mean the centre hub wasn't going round? Switching on the ac, does the clutch click to engage or does nothing happen? If you can hear the clutch clicking but no engagement, it may be that the shims need adjusting (removing a shim will allow the clutch to pull in and engage). If there is no clicking when switching on the ac, the relay may be faulty.
MJP02 Posted July 8, 2016 Posted July 8, 2016 easy way to see if it needs just a re-gas, pup the pressure switch off the pipe work near the rad, short out the 2 pins with a bit of wire, start car and turn on the ac, if the clutch engages then its low pressure meaning try with a regas and pressure test
Hirschhs Posted July 9, 2016 Author Posted July 9, 2016 I actually had it regassed but the level was fine. The mechanic separated an electrical plug and bipassed it, it didn't work. There is no click or sign that the a/c clutch engages. I think, though I now wish I'd watched more closely, the centre hub wasn't turning. I can recheck tomorrow. I can also change the relay...
Hirschhs Posted July 13, 2016 Author Posted July 13, 2016 So I checked the relay and it's missing! That's not going to help is it! Just need to find one now... 1
Jay762 Posted July 21, 2016 Posted July 21, 2016 Wotcha and welcome - sounds like a potential easy fix
Greenmamba Posted July 21, 2016 Posted July 21, 2016 Maybe you need a new mechanic as well! He/she ought to have spotted that. Good luck.
Register a new accountSign in
