Right peeps, what oil filters are we supposed to use, I just get a pattern one when I buy the oil, I'm hearing that we should only use the Subaru blue ones, but on googling that fact there are a lot of people saying absolutely don't use the Subaru ones as they are awful
cant say i have had issues  with the subaru one. i however use an aftermarket one as i got a deal on it
Always stuck to the Subaru one that import car parts offer. Genuine Subaru part and doesn't cost the earth. They do a service pack including oil filter, air filter and fuel filter for £12.50
I got the hks one because it has a magnet in and said higher oilflow. Whether it's any good I have no idea won't find out till I have a problem or do my next oil change
Expand
they are amazing. i had one on my closed deck build in my bug last service.
I normally buy a Mahle oil filter from Opie Oils with my oil and sump plug washer .(Mahle make quality forged pistons so I assume they're capable of making a filter)
I did try a k&n oil filter once but didn't see any difference in pressure or temps just cost me a extra tenner
  On 10/4/2016 at 4:23 PM, savage bulldogs said:
I normally buy a Mahle oil filter from opie oils with my oil and sump plug washer .(Mahle make quality forged pistons so I assume they're capable of making a filter)
Expand
Amazon have k&n filters for less than 9 quid... do they have some sort of super duper one?
I bought a oversized (and over priced by the sounds of it lol ) k& n filter with a "easy to remove" nut on the bottom .
Dunno if it the same 1 that you've found ,as it was about 4 yrs ago and about £15
P.s I forgot to mention that the only reason I bought it was because there was a load of fake or faulty subaru ones on the market at the time . The Mahle one's seem to work fine on mine but I do 4 k changes anyways
Expand
Ah ok... i've got a k&n one, it has the nut thing on the bottom... was gonna replace my filter when i was doing my rocker cover gasket but i didn't have anything to remove the old filter so didn't bother... it was only 500 miles old anyway
I wouldn't recommend K&N oil filters - !Removed!!
Usually OEM must be the BEST ones! Some German manufacturers can make quality filters as well. But overall we need to collect some cash, buy all the different filters - cut them and see what's inside only then we can decide which one is the best to buy.
If magnet REALLY is a big improvement for you, why don't you brake an old speaker, get a magnet from there and stick it to your oil filter? Every oil filter is made of metal and a massive magnet next to it will make the whole filter magnetic as well. Alternatively you can disassemble a faulty hard drive - they have mega strong magnets inside and old automatic gearboxes if you drop a pan there will be a few small magnets as well -)
