Help, looking to purchase Hawkeye STi
I'm still getting just under 30mpg since June....dropped a bit recently due to colder weather but still got 28+ with the last tank.....about 270 miles as a rule but I fill as soon as it gets below 1/4
  • Replies 110
  • Views 11.7k
  • Welcome to the club Steve! Personally, I would go for the 04 Blob. 2 litre engines have less problems with headgaskets and ringland failure. I would still make sure that the cambelt has been done
  • walk away from anything in bradford. i noticed clives performance has changed name again ca performance or summit like that
  • Will check them out.   Yeah, peanut/blob same thing. I'm a Yank by birth, cut me a some slack 😉😂
Something must be wrong with mine then...only working out o 9mpg at current rate and I'm not hammering it! If anything I'm short shifting massively? Maybe that's my mistake?
Another note, are Subaru's supposed to be fairly loud road noise wise inside? Haha. Gearbox creaks and groans a bit at full lock turns, and it sounds a bit creeky when going over speed bumps.
What tyres is it wearing?
Yokohama Advance Sport V105 225/45/17 on stock STi alloys
The suspension top mounts are prone to knocking after a while... in terms of creaking on full lock, power steering belt perhaps?
Is this something that should be looked at? Or is it just noise? That should of been caught on a MOT?
From what I've read, it's just the STi transmission, it groans a bit?
Does yours have the dccd ?
If the box is cold it's usual to get a little nvh
Yep. Widetrack.
The car looks great. Only one way to check the milage and that is to fill it up and get out there and drive her. Enjoy.
