Am I the only Impreza owner to have this issue?
Hi guys,
I've now been all over the internet looking for any info on this and I'm can't find a single post!
The problem is that the indicator stalk on my 98 UK Impreza doesn't cancel 98% of the time. I know it's only a minor issue but I've not long bought the vehicle (my first) as a bit of a project and want to fix all the little niggles.
The question is if I buy a new indicator stalk will that solve the problem or is there a cancellation peg on the steering column that can be adjusted and has anyone ever done it or will I have to buy a new one?
I'd rather try and repair it myself rather than send it to a garage.
Thanks for reading!
Not a problem I've ever come across to be honest, I think the stalk sits on a 'ring' that cancels it so you'd more than likely have to buy the stalk & assembly I'll try and find a pic
This may have be some use ?
Cheers Stants,
I watched 30 seconds of that video yesterday but turned it off when I realised it wasn't the same fault however just watched it all and it seems a pretty easy job.
From looking at pics the stalk housing switch looks plastic or nylon so I think I'm gonna try swapping the housing out first. There's a few on eBay going cheap.
Thanks.
Not much help but my 2010 Impreza does this aswell. Can only presume people before used to jam the thing
Can't say I've had a issue with either my 97 UK turbo or my 94 sti but both of those were under 90k mls .
Just thought i mention that The early classic uk's and jdms have the indicator stalks on the opposite sides and I'm not sure if they're universal ( so try to get 1 off the same year /version )
not had that myself with 08 models - pull the wheel off and dash cowl - easy job and check all the tabs
OK,  so a quick update.
Got a new stalk unit and popped it in but same problem...... If I turn the wheel over a full rotation it will cancel but under normal driving conditions it won't budge. I'm starting to wonder if it has a steering column from a jdm (as Savage mentioned they have the indicators on the other side).
